gfxgfx
Welcome, Guest. Please login or register.
Login with username, password and session length
Vote for this site!
gfx gfx
gfx
235550 Posts in 20695 Topics by 8811 Members - Latest Member: jllybrns01 December 15, 2018, 02:14:53 AM
gfxHomeForumPicturesHelpSearchGamesMobileProfileEventsLoginRegistergfx
gfxgfx
0 Members are viewing this topic.       « previous next »
Pages: [1] Go Down Print
Author Topic: straps vs chains  (Read 16401 times)
Super Member
Offline Offline
Gender: Male
Trade Count: (5)
« on: October 08, 2011, 11:52:36 AM »
alright guys i have always heard evryone say to use a recovery strap when yanking some one out and have been told tht straps are better then chains. But im just being curious trying to learn what makes a strap better or safer then a chain i know tht a strap stretches but it just seems like chain would be stronger then a strap.if either break they could kill u
Logged
Muderator
Gold Member
Offline Offline
Gender: Male
Trade Count: (40)
U CAN'T RUNWITH THE BIG DOG WHEN U PISS LIKE A PUP
WWW
« Reply #1 on: October 08, 2011, 02:12:18 PM »
i could also hit you with 5lbs of strap or 20 lbs of chain.   the strap is made to stregth and then recoil for a pop up and pull  methed and are rated      and yes you can get to big or to little of a strap also.
 chains are also rated  most ppl dont buy a high grade  chain
 the straps are easyier on both of the trucks at the same time    than a solid snap when you come to the end of a chain also.
Logged
break it, fix it, try it again!!!
Super Member
Offline Offline
Gender: Male
Trade Count: (5)
i'm not stuck, watch this!!!
« Reply #2 on: October 08, 2011, 10:15:18 PM »
the straps and tow ropes have an elastic stop to them that chains don't have, the chains hit hard when you jerk and are more likely to do damage or break than straps or ropes are
Logged
chevrolet all the way Yeee Hawwww There's plenty of room for all god's creatures............ right next to the mashed potatoes.... Yeee Hawwww  chevrolet all the way
I work at GM, I drive GM
Super Member
Offline Offline
Gender: Male
Trade Count: (16)
Let's go wheelin....
« Reply #3 on: October 09, 2011, 12:13:24 AM »
chains are not rated for impacts, like when you jerk a truck out, straps are.  chains are good for a steady working load, and for high wear straps are for high impact.  so if you are dragging logs through the woods, use a chain.  If you are trying to pull your buddies truck out of the mud, use a large enough strap for the truck.
 *******Without good safe pull points, neither straps nor chains are safe!*******
Logged
GMCBow Tie!
muderator
Super Member
Offline Offline
Gender: Male
Trade Count: (8)
« Reply #4 on: October 10, 2011, 12:02:01 PM »
http://wegotmud.com/forum/index.php?topic=40331.0
read this, very good info..
FYI - without proper and secure pull points the strap/chain is just about useless.
Logged
Super Member
Offline Offline
Gender: Male
Trade Count: (5)
« Reply #5 on: October 14, 2011, 09:58:09 AM »
lets say they dont have a front tow hook, wrapping a strap around the  front axle and running it back through itself good? bad?"
Logged
muderator
Super Member
Offline Offline
Gender: Male
Trade Count: (8)
« Reply #6 on: October 14, 2011, 12:10:02 PM »
is good..
better would be to strap the frame..
helps reduce movement of the towed rig..
yea.. body sway still happens to a trailered rig.. this minimizes the tail wagging the dog effect
Logged
Jthomas
Sr. Member
Offline Offline
Gender: Male
Trade Count: (8)
I Do Big Blocks
« Reply #7 on: June 10, 2012, 06:59:34 PM »
Chains just brake parts. I watched at an event a guy jerking a guy out with a chain, bent his frame to shitt. Bent it so bad that it turned the leaf spring shackles, bent the tow hooks, and tore the bolts through the frame that held th hooks on. Not to mention, if it broke, it would be alot more devastating than a strap.
Logged
Women+Trucks= Heaven
Gold Member
Offline Offline
Gender: Male
BOGGER UP
« Reply #8 on: June 12, 2012, 05:46:45 AM »
and thats another reason not to use bolt on tow hooks, if you want to use hooks like that WELD them on.
Logged
Need a strap?
Super Member
Offline Offline
Gender: Male
Trade Count: (11)
« Reply #9 on: February 23, 2013, 11:29:53 AM »
Chains are not meant to be jerked... these people were idiots.  A steady even load pull, a properly sized chain works great.  But usually that is not the case when talking about mud bogs... so straps are where its at.
Logged
steven94
Drives Barbies Jeep
Offline Offline
« Reply #10 on: October 30, 2014, 11:06:49 AM »
deff straps screw chains
Logged
steven94
Drives Barbies Jeep
Offline Offline
« Reply #11 on: October 30, 2014, 11:07:47 AM »
chains break and coil i seen one tear through a military humvee
Logged
treefarmer
Jr. Member
Offline Offline
« Reply #12 on: March 26, 2015, 11:26:52 AM »
strap are way go
Logged
Hoss4wd
Super Member
Offline Offline
« Reply #13 on: March 28, 2017, 12:56:12 PM »
Straps for sure!  Lighter and safer!
Logged
gfx
Pages: [1] Go Up Print
gfx
Jump to:
gfx gfx
