==shrug What do you carry in your truck to get you out of a tight spot?
Mine has:
Hi-Lift
6' section of chain
tie down ratchet straps x2
tool box with standard hand tools (tire plug kit, elec tape, test light,extra nuts/bolts,)
4' wrecking bar
tow strap and screw type clevis's
flash light
propane torch
Duct tape
fire extinguisher
a buddy's phone #
that kinda depends on where I'm going....If I'm going somewhere where I will remain fairly close to the tow rig, then I take 2 of everything I think I may need, and 1 of everything I dont think I will need....then I only have to borrow the minimum...(like gas...DOH!)
if I'm on the trails and nowhere near anything, and have to carry everything in the truck I'm wheeling, I'm a bit more picky about what I carry....I dont want to carry around a bunch of weight for no reason...thats when I will take only tools that fit my truck (preferably anything with multiple uses) certain spare parts that will need to be replaced on the trail if they fail (I'm never going to rebuild an engine on the side of the trail) and just enough fluids for 1 change of each (just in case)
a=f what tool box loll ==dj a=f
basic tools in my sami would be fire ext. and towstrap, screw driver, winch, and few fluids including a gallon of fresh water the rest of other tools stays in my tow rig and the situation would be different if i plan to be more than 5 miles away from my tow rig, more tools would be on board... and if i m far away from home like going up north wheeling sometime if i feel uncomfortable i d bring generator and mig welder and air compressor.
i dont have a tool box in my truck but when i go to a bog i normaly have 1 of everything as far as tools and a set of axles and u joints and a strap
when I go out I bring 2 or 3 tow straps, screw in clevis or 2. and A few small tools , and gas. if my truck breaks at a bogg I just have some one pull me on my trailer and I am done for the day. I use to bring hi jacks, parts, lots of tools all kinds if stuff, now I dont worry about I just have fun till it breaks the relax the rest of the day!!!!!
i bring tow straps few tools only the most use ones the only spe tools are the hub socket and a cell phone and i have a cb for wheeling in the U.P i keep darn near all my xtra parts and tools in the tow rig when i go up nort to the U.P
I'm with Uncle Steve....What tool box loll loll
i need to get some tools first :)
two tow straps
a come-along
fluids for trans, power steering, brakes, and coolant
basic hand tools and socket sets
a nice cigar.....
2 straps,3 screw clevis`s,hi-lift jack,come along,fire ext.,extra fluids,complete socket set,screw drivers,channel locks,duct tape,spare belt,wire,waterproof matches,cell phone and the wife to snuggle with if we get cold!!!!!
50' of strap and a cellphone!
- 2 spare cv shafts.........luckily I have never needed them but I have sold them trail side for 3x what I paid for them since to others who were less prepared.........and no I did not rip them off..........they set the price LOL
- enough tools to change the cv's...........I am getting pretty good and quike at it since people who don't think to bring spares can't change them either LOL
- basic hand tools
- fluids..........I don't bring enough for a full change since i try to avoid deep water which lessen the chance of needing to change all the fluid.
- food and drink for me.............i need to be able to think strait when wrenching and that is difficult when you are hungry and dehidrated
My truck is pretty heavy when it is loaded but when you have drove the truck 800 + miles from home to wheel and you need it to make the same trip back home you better go prepared LOL
2 sets of scokets, standard and metic, one sets the little scokets and one sets deep whel,
3 foot breaker bar,
25 foot chain, 15 foot tow strap.
extra, differental covers. axle shafts, extra pair of lock out hubs ,
Big ass hammer,
3 foot pry bar,
2 3 inch ractert straps, and 2 1 inch rachet straps,
gear lub, oil, antifreze
tire repair kit,
extra distributor, extra set of spark plugs,
power inverter, big enough to use my wire welder.
test light, head gaskets,
extra set of heads
intake and intake gaskets
Hi lift jack(with all the p00 to go with it)
every socket,drive,extention,wrench,pliers, and breaker bar possible
2 tow straps
2 screw clevises
u joints,axle joints
tire repair kit
spark plugs
blow dryer(for drying out an engine after swamping it)
power inverter
on board air and welder
spare gas
fluids(oil anti freeze axle grease and oil,trans lube,brake fluid stop leak stuff for all the above)
2 fire exts
duct tape (red water proof stuff)
belts
wires
cap
rotor
cb radio
and a cell phone
i go out to moab alot so most of this is needed
6pak & cell phone
thats a joke
duct tape is all u really need.. and a celly
holy old post
ok just a small kit in both dd bogger box is a decent set its a chevy 2 of each 1/2 9/16 5/8 4 way brake tool and axel nut tape and zipp ties
I got a Cell phone and a triple A card ;D
30'x4" strap,clevest ,bfh,start fluid,jack,blocking,2 shovels,az/ax,5' RXR bars,fence post,2 tool boxs one of piers screwdrives and such one just sockits and renchs,spaer bolts,wier tester,spaer wier,tinker toy compresser,fluids jumper cabuls
and a pile of randum p00 yull never no what all you nied tho
nothin in the bogger but a strap and cleviss every tool i think i might need is in the tow rig bring on ly the simple parts to fix dont have anything if i start breakin big parts itll go on the trailer
30' 6" strap
cleveses
in tow rig
oil
trans fluid
wires
cap n rotor
wire
starter
hubs
axle shafts
ton of tools
if brake anything big load n go home
Small Military folding shovel
Duct Tape
Tow Strap
Winch
6' Chain
Hi-Lift
Tire Blocks
Tool Box (tools, few u-joints, wire, zip ties)
Few Clevis's
4 way
Cell Phone
Fire ext.
Fluids
Cb radio
Pretty Standard issue stuff but it has come in very handy
wrenches, socket set, 12v test light, jumper cables, umm im forgetting stuff but i bring stuff to fix in case i break down on the road.
tool set, small tool box with hammer, duct tape, funnel, electrical tape, Wd-40, wire brush,wire, wire sleeves, etc. Floor Jack and jack stands 4 x 6 block of wood, spare belt, pipe for extra leverage, jumper cables, A snap strap, a 4 way, etc. I use it for daily driving and wheeling.
