Projects & Parts => Garage/Tech => Topic started by: sandmand on July 18, 2008, 01:54:02 AM
Title: 94 jeep rearend help
Post by: sandmand on July 18, 2008, 01:54:02 AM
 hey can anyone give me any ide i have a 94 jeep grand cherokee  and im getting a clicking/ grinding noise but only when not under load when you let off the gas help
Title: Re: 94 jeep rearend help
Post by: Ranger Dave on July 18, 2008, 02:10:10 AM
check your  ujoints.   ==dunno
Post by: Mudbuster on July 18, 2008, 02:16:59 AM
Quote from: Ranger Dave on July 18, 2008, 02:10:10 AM
Post by: Fraser on July 18, 2008, 03:14:18 AM
Quote from: Mudbuster on July 18, 2008, 02:16:59 AM
X3  also, if that isnt it, open up the cover and check the carrier out.  the rear that was on my jeep had the pinion grinding on the carrier. I cant tell ya what that sounds like tho, wasnt on there for very long after that, and wasnt my dd
Post by: sandmand on July 20, 2008, 05:47:58 PM
just replaced bouth u joints and puled the cover look good but i thought the inter and outer bairing were bad sow i reaplaced bouth and seal on outer and this is a all weal drive i chenk the tranfer cace all ok and the frunt all good
Post by: sandmand on July 21, 2008, 01:26:29 AM
hey dose any know how to see my rear end tork speck  sow i can get it back toghter i found a bad bairing on the inter and outer of the drive splin on the pinion seal and anything i may need to put this dam thing together please help!!!!!!!!!!!!!!! thanks it is a 373 gear
Post by: sandmand on July 21, 2008, 01:27:37 AM
sorry set my rear end
Post by: Fraser on July 21, 2008, 01:34:54 AM
you got it?
Post by: sandmand on July 21, 2008, 02:01:53 AM
I took apart the pinion and it seems it is that since all the bearings are chunked out and the races are chunked out too! But now my issue is I'm not sure of the exact spec's to put it back together so I don't mess up what I already did. Since the auto parts store closed just before I found it I have to wait till tomorrow now.  So if you know what I need to do exactly please help me out! Thanks!!
[/quote]
[/quote]
Post by: Fraser on July 22, 2008, 03:25:45 PM
what kind of rear end is it? dana 35? or the 44a
