Projects & Parts => Garage/Tech => Topic started by: 96_Bronco on August 12, 2008, 03:11:57 AM
Title: Need help on my truck issues
Post by: 96_Bronco on August 12, 2008, 03:11:57 AM
My truck is going in the body shop tomarrow to get some cancer takin care of before winter and I'm trying to figure out why my low 4 doesn't work High 4 works great but low won't engauge I hear it might be a fuse but I can't find where it would be... I'm trying to avoid going and buying a hayes book at the moment..... a lil insight on the truck. 1996 Bronco XLT 302 motor not sure what tranny or transfer case. it does have Warn maneul lockers on the front with the 4 high and low push buttons inside. if I push the high I can hear it engauge (if my stereo system is turned down) light comes on on the button and my 4X4 Light come on in the cluster. but If I push low nadda nothing at all.... any Ideas??????? I would like to go through the whole rock course but I can't with 4 high with out tearing up my truck...
Title: Re: Need help on my truck issues
Post by: Bigdaddy on August 12, 2008, 03:18:42 AM
nice ole bronc , i moved topic to garage / tech  ==goodluck
(http://wegotmud.com/pictures/8-10-2008B/100_8878.jpg) (http://wegotmud.com/pictures/8-10-2008B/100_8878.jpg)
Post by: CRAZY MAN broncomudhead on August 12, 2008, 11:52:33 AM
callme or stop by we'll figure something uot 8103978401
Post by: blasterguy911 on August 12, 2008, 06:35:29 PM
it sucks get shifter
Post by: Fraser on August 12, 2008, 09:34:09 PM
might be the shift motor on the t-case, and/or the harness going too it. my cousins old ranger had this problem
Post by: 96_Bronco on August 13, 2008, 02:13:19 AM
I just dropped off the truck to the bodyshop today when I get it back maybe friday I will check the wiring first. if I find nothing wrong which won't be suprising I'm not a wire guy I will give you a call bronco and hopefully it won't cost me too much in parts
Post by: J.C. on August 13, 2008, 02:20:22 AM
not trying to be a smartass, but did you put it in neutral at a dead stop and try it?
Post by: Ranger Dave on August 13, 2008, 02:36:44 AM
you  must  be  in 4 hi, then be  at a  stop. put trany in nutral.    then push the  4 low  button.    if it  not that,  its most likeley your  motor under there.
i had  a  94  bronco, ands  had that same trouble.  it was the  motor.
Post by: 96_Bronco on August 13, 2008, 03:49:50 AM
actually I have tried everything but having it in 4 high first... I knew about nutral but I always turned of 4 high first... I'll have to try that
Post by: RIP_K52007 on August 13, 2008, 03:56:50 AM
make sure you can start the truck with it in neutral, if the neutral switch is bad it wont start, which means it wont know its in neutral to let u put it in 4 low either.
Post by: 96_Bronco on August 14, 2008, 11:13:33 PM
ok went to the body shop today and 4 low works I didn't know you had to have 4 high engauged as you pushed 4 low it works problem solved and I feal like a moron now but it's all good... thanks for everyones help
Post by: J.C. on August 15, 2008, 03:11:37 AM
dont feel like a moron. it happens. glad to hear it doesnt cost you any cash to fix it!!!
Post by: ~SwampRAT~ on August 15, 2008, 03:49:02 PM
ya, awesome it didnt cost you anything...btw that is a beautiful bronco.....
