never had a problem with my accelerator sticking when i was running my edlebrock but i got a holley 650 on my 460 when i got it and its been running so good i dont wanna swap on my predator till i have to. anyways, the accelerator keeps sticking on my holley. ill soak it down with PB Blaster and loosen it up and its pretty good for awhile. when i go bogging though the dust seems to totally reverse what the PB Blaster had done. i put on an extra spring as well and still it ends up sticking when im bogging. i guess my question is what do you guys do to keep this from happening? and little tricks or anything that you guys know? thanks in advance.
Sounds like a ford thing. Ha ha just kidding. I could tell ya
i always covered my linkage joints with light grease if they stuck while offroading and problem solved. helps keep the dirt out of the linkage. also isnt there like a float needle or something in there that moves with the throttel that can stick also?? not sure
Quote from: KORNBREAD on August 26, 2008, 03:08:35 AM
ya but thats not my problem, its the actual linkage. i thoguht about the greese thing too, thanks.
clean where the throttle plate touches the body of the carb, if its gunked up it will stick a lil
