Projects & Parts => Garage/Tech => Topic started by: 84Chevy on September 02, 2008, 12:59:32 AM
Title: 1999 serp. setup swap onto small block
Post by: 84Chevy on September 02, 2008, 12:59:32 AM
will the water pump work?? i know i gotta redo my steering pump because of my hydro steering but other than that is it pretty much bolt up? o yeah its off a 4.3
Title: Re: 1999 serp. setup swap onto small block
Post by: 84Chevy on September 02, 2008, 01:17:20 AM
i have the complete 4.3 it has everything....
Post by: Mudbuster on September 02, 2008, 01:22:13 AM
yes the serp setup off 4.3, 5.0 and 5.7's will work on an older smallblock you just have to use the water pump off an 89 or newer 4.3, 5.0 or 5.7 since they are counterclockwise rotation. I've got a serp system off a 91 4.3 s10 on my jeep.
here's my setupnot the best pic but here it is anyways.
(http://i100.photobucket.com/albums/m29/mudbuster/jeep/DSC00065.jpg) (http://i100.photobucket.com/albums/m29/mudbuster/jeep/DSC00065.jpg)
Post by: 84Chevy on September 02, 2008, 01:26:06 AM
sweet so i shouldnt have to buy anything!!!! im gonna even leave the ac so when i switch the bodies this winter ill have ac in the blazer!!!!!!!!!
Post by: 84Chevy on September 02, 2008, 01:28:17 AM
i cant plug it?? be right back with some pics
Post by: Mudbuster on September 02, 2008, 01:31:13 AM
Quote from: toughbowtietruck on September 02, 2008, 01:27:00 AM
Quote from: 84Chevy on September 02, 2008, 01:26:06 AM
so long as the 4.3 waterpump doesnt have the extra press fit piping on it
1994 or so and newer they added extra hoses and press type pipes to the waterpumps on all the engines.
Also they changed to a screw nut fan setup where the fan screws on the waterpump flange
neither of which should be a problem if you don't need the fitting for the heater then cap it off, as for the fan I'm sure he's running an electric fan so it won't make a difference.
Post by: 84Chevy on September 02, 2008, 01:31:51 AM
Quote from: toughbowtietruck on September 02, 2008, 01:29:42 AM
Quote from: 84Chevy on September 02, 2008, 01:28:17 AM
It would look dumb for one thing
I dont think it would hurt it, one goes into the intake and the other into the heater core
a new one is less than 40 bucks if its NOT the screw nut fan type
whos gonna see my water pump???
Post by: 84Chevy on September 02, 2008, 01:32:08 AM
yes runnin electric fan....
Post by: Mudbuster on September 02, 2008, 01:34:44 AM
Just do it you'll be OK I've done it to two of my own vehicals and it works fine ==np ==np
Post by: 84Chevy on September 02, 2008, 01:57:25 AM
(http://i76.photobucket.com/albums/j30/84chevy2/shit002.jpg) (http://i76.photobucket.com/albums/j30/84chevy2/shit002.jpg)
(http://i76.photobucket.com/albums/j30/84chevy2/shit003.jpg) (http://i76.photobucket.com/albums/j30/84chevy2/shit003.jpg)
(http://i76.photobucket.com/albums/j30/84chevy2/shit004.jpg) (http://i76.photobucket.com/albums/j30/84chevy2/shit004.jpg)
(http://i76.photobucket.com/albums/j30/84chevy2/shit005.jpg) (http://i76.photobucket.com/albums/j30/84chevy2/shit005.jpg)
Post by: Mudbuster on September 02, 2008, 02:00:40 AM
that'll work just fine you'll either have to plug off the water pipe on the pump or hook it to the heater core and remember what it's from so if you need to buy part's latter on you can get the right ones ==np
Post by: 84Chevy on September 02, 2008, 02:04:47 AM
right on.. i plan on runnin the blazer body next year .. heat and a/c are a plan!!!
Post by: Mudbuster on September 02, 2008, 02:06:41 AM
well that'll make remembering where the parts came from easy won't it loll ;) ;)
