Projects & Parts => Garage/Tech => Topic started by: J.C. on October 26, 2008, 01:37:55 AM
Title: will it fit
Post by: J.C. on October 26, 2008, 01:37:55 AM
do all the 73-87 cabs bolt down the same. like mounting holes and all. i got a 75 frame, will a 81-87 cab bolt on?
Title: Re: will it fit
Post by: J.C. on October 26, 2008, 12:42:07 PM
ok so i can also use a 3 inch body lift as long as i use the 73-77 body  bushings?
Post by: Bowtie972 on October 26, 2008, 01:00:29 PM
 Are you restoring this or is it your bogger?   On mine I made my own body lift and then added a hockey puck instead of body bushings.    Then made some large diameter washers for the bottom side of the mount, done this more than once with no troubles.  Just an idea.
Post by: J.C. on October 26, 2008, 01:17:33 PM
bogger
Post by: Orangecrush on October 27, 2008, 12:17:49 AM
Quote from: Bowtie972 on October 26, 2008, 01:00:29 PM
I seen this set up, very well made, works great!!   cheap too$$$
