any things i have to do to switch my D44 out for a D60? and can you run 15" wheels on a D60?
you can runn 15 " wheel on a D60 just have to grind the calipers.
if its chevy to chevy, you should be ok other than a ujoint other than that ==dunno need nore info on what it came out of and what its going in.
Is your D60 a Dodge or Chevy? I think their is a spring perch width issue when using the Dodge axle in a Chevy, chevy is direct swap, My Corp 10 to a D60 was pretty much a direct swap, except for a few things...........Larger U bolts, different steering correction parts, brake calipers and hoses
15" rims will work on a D60 with ALOT of grinding!!!!!! I had probably at least 2 hours a piece in grinding the calipers down, not fun at all! 16's or 16.5's are the better choice but I used what I had which was 15's.
My Ujoint in the front shaft was exactly the same as corp 10, Im sure their are other sizes out there though.
15 in wheels with no more than a 2 in off set if its a dually grind the hell out of the calipers maybe front u joint and a ubolt top plate if you dont get them all ream the 2 holes a little
If you have a dually setup, and don't want the extra width.. you can cut the hubs down.
