Projects & Parts => Garage/Tech => Topic started by: Captn. J on January 30, 2009, 08:51:05 PM
Title: transmission seal
Post by: Captn. J on January 30, 2009, 08:51:05 PM
after putting it all together  found it leaks out of torque converter area so  i m gonna replace the input seal and  the pump seal , wonder on a ford  C-6 is the pump seal replaceable without removing the transmission pan?
Title: Re: transmission seal
Post by: CRAZY MAN broncomudhead on January 30, 2009, 08:57:09 PM
yes but you have to pull trans out then pull pump out the front there are two holes to use with the puller and i think they are at 1 & 7 o'clock
Post by: Captn. J on January 30, 2009, 10:25:26 PM
Quote from: broncomudhead on January 30, 2009, 08:57:09 PM
where do u get the pump n puller? or can i use some kind of tools?
Post by: CRAZY MAN broncomudhead on January 31, 2009, 12:35:56 AM
rent or buy one at a tool place
Post by: Captn. J on February 05, 2009, 03:06:00 AM
will autozone have it as a rent-a -tool? the pump puller? do u have to have that to remove the pump cover? mine seal is leaking assuming since i replaced the torque converter seal and it still leaked..  gonna pull it down again
