i need a tube for a 33-12.5 r15 so i went down to tsc and all thers only say what sive rimm and its use (i.e. car, light truck, trackter, floater....) was wunderin howdo i tell what size tire thay will fill ???
i put a flotation [flot] tube from tsc in my 35/16/15
Quote from: yamaha7244 on March 29, 2009, 01:20:20 AM
x2 There should be a chart on the back of the box. See if any of the dimensions they give look close to your tire. I opened up a couple boxes and layed the tube out and measured. Problem with flotation tubes is the valve stem is larger around than a regular car tire so you'll have to drill out your rim a little.
==thanks thats the way i was leaning but wasint sure, thout id ask around befor i bought one
