Projects & Parts => Projects => Topic started by: Hammerlane on April 13, 2009, 05:38:43 PM
Title: Redheaded stepchild
Post by: Hammerlane on April 13, 2009, 05:38:43 PM
Yep, wifey wanted a toy (besides me) to play with in the mud..
traded a buddy my 99' pickup truck straight up..
86' Jeep CJ7
no motor
350/205
D30 front w/locker
9" Ford rear welded
36" tractor V treads on the rear
Swampers on the front
To date:
Front axle has been completly rebuilt
305  .030 over motor is in
wiring for fans, fuel pump is done
replaced windshield frame for one that has a windshield in it.
have a hard top for it, need doors
Still needs:
Trans pan changed
oil change on Tcase
rear axle rebuilt
fuel cell removed and original style tank installed
wire the starting/ignition system
seats need to be relocated so she can reach the pedals
seat belts are inop.   seized.. gotta fix that.
trans tunnel pan - fab and install
wire the headlights
install the hard top (with sunroof !! )
L front hub still needs to be installed
grease EVERYTHING !!
Power steering hoses/pump install (gotta make brackets)
ah crap.. I can't have this much to do..  ==doh
new brake lines for the front
wiper motor (need one.. if ya got one for sale post up please)
rear seat (need one of them too)
GotMud? sticker for the back window
oh.. and last but not least..
it needs a  NAME  woman !!!!!!!!
Title: Re: It's Hers !
Post by: betterbeaters on April 13, 2009, 05:41:21 PM
sounds like fun!
Post by: Ranger Dave on April 13, 2009, 06:16:12 PM
get r done !
Post by: Hammerlane on April 16, 2009, 05:20:58 PM
2 issues I'm tryin to work around:
1.  305 GM motor, R side water pump pickup, and L side radiator lower..
so far Ive taken 2 radiator hoses and cut them apart, installed one on the water pump
and 1 end on the radiator, I now have to connect them right below the vibration dampener..
exhaust pipe?? or PVC pipe?? It needs to be a 90 degree bend..
concern: if I insert a piece of bent pipe I will restrict coolant flow.. radiator is small enough as it is..   any suggestions?
2. Lower coolant hose will interfere with the PS pump.. I can just make some new mounting brackets and raise the pump.. but should I use a Jeep pump, or will a standard GM pump work..
concern: pressure hose from the pump to the gear box.. are they compatible or will I have to install a reducer on the back of the pump to get the line to fit properly??
Post by: TopFist on April 16, 2009, 08:30:41 PM
Any good radiator shop can cut and switch the inlet ond output. I had one done last year in lansing for $50.
Should be able to use the GM pump.
Post by: Bigdaddy on April 16, 2009, 08:50:39 PM
wheres the pics?
Post by: TBigLug on April 16, 2009, 11:56:20 PM
Quote from: Bigdaddy on April 16, 2009, 08:50:39 PM
wheres the pics?
Post by: Orangecrush on April 17, 2009, 02:53:26 AM
I wanna see sum pics, sounds like  COOL MUD TOY!!
Post by: CRAZY MAN broncomudhead on April 17, 2009, 02:57:15 AM
name her Slippery when wet or wet and slippery and a pic or two would be nice
Post by: Eroq on April 17, 2009, 04:03:50 AM
it looks pretty sweet, aint seen it up close yet..
==takeapic
Post by: mathew21 on April 17, 2009, 04:05:50 AM
Congrats
Post by: Hammerlane on April 17, 2009, 05:05:17 PM
Quote from: sand devil AKA broncomudhead on April 17, 2009, 02:57:15 AM
what.. the wife or the jeep??
Post by: Hammerlane on April 17, 2009, 05:07:08 PM
try and get some pix up this weekend..
body's in ruff shape, eventually the VW body will go on it.. still bending tubing for that.
Post by: Hammerlane on April 17, 2009, 05:09:25 PM
Quote from: 454 Jeep on April 16, 2009, 08:30:41 PM
==doh
Post by: CRAZY MAN broncomudhead on April 17, 2009, 07:10:17 PM
the JEEP what are you trying to get ME in trouble and get your sef out a jam
Post by: Big-Al on April 18, 2009, 01:23:39 PM
 HELL  YA .........PICS OF THE WIFE...............loll  loll .
gm pump will work fine. if ends are different, car-quest in fenton can make or splice yours together.
i have a cj rad. with both  chevy and jeep ends.  $75.
Post by: Hammerlane on April 18, 2009, 02:50:59 PM
Quote from: Big-Al on April 18, 2009, 01:23:39 PM
I'll keep that in mind (rad.) .. gotta hose made up for it.. we'll see how well it holds up.
and I'll talk to the wife bout those pix ..  ;D
Post by: Hammerlane on April 18, 2009, 04:09:23 PM
pix of the wife up later  ;D
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0281.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0281.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0282.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0282.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0283.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0283.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0284.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0284.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0285.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0285.jpg)
Post by: CRAZY MAN broncomudhead on April 18, 2009, 09:18:05 PM
new name cancer baby! and i still can't get that CB to work won't put out at all just like most peoples wife's and it is a little hard to come and see you it's just to dam far to drive you know what I meen so give me some feed back
Post by: Hammerlane on April 19, 2009, 03:40:52 AM
Quote from: sand devil AKA broncomudhead on April 18, 2009, 09:18:05 PM
ah come on.. vegas is only a 35 hr ride.. I've done it several times..
Post by: CRAZY MAN broncomudhead on April 19, 2009, 04:19:45 AM
well next time you do the ride let me know and we can do some thing with it
Post by: Hammerlane on May 02, 2009, 11:43:03 PM
It tis AAAAALLLLLLLLLLLLLLLLLIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIVVE!!!   ==evillaugh
Yep, she breathed fire tonight..
worked on it most of the day, wired ignition and start all thru an oh sh** switch, pull the plug and ALL the electrical shuts down.
put a Holley on it.. motor did'nt want anything to do with it so I shot up town and got a brand new Edlebrock 600 cfm..
some other "needed" things.. rerouted the fuel thru the manual pump (guy that built it had the elec. fuel pump under the hood {pusher type})
I'll fix that later..
primed the motor (oil) with an old dist shaft and a drill (motor has'nt been fired since I bought it 5 yrs ago, I've never heard it run)
wired it up, had an issue with being off a tooth.. figured it out in a minute or so..
filled a beer bottle with gas (40 oz) dropped the fuel line in it (really, what else do you think I was gonna use)  beerr
had the wifey hit the switch and  ==wtf and next thing ya know  ==rant ==oops            Pi**ed Off neighbors   ==tka  ;D
Runs GRRRRRRRRRRRRRRREEAT, strong and smooth..   tranny, rear end, L hub, fuel tank, seat belts, top amoung others yet to do..
Post by: Hammerlane on May 05, 2009, 03:45:27 PM
Got the fuel cell flushed
installed brake booster and (bad) master cyl.  - has power brakes now..
still need to install a new master cyl.
drivers side 5 point harness almost in
hmmmmm.. mounds!?!?
Post by: Ranger Dave on May 05, 2009, 04:09:58 PM
get r done !
Post by: Hammerlane on May 05, 2009, 04:13:22 PM
Quote from: Ranger Dave on May 05, 2009, 04:09:58 PM
get r done !
We be gittin !!   ==wrenchinbanana ==dancinbanana ==wrenchinbanana
Post by: Fraser on May 06, 2009, 04:37:59 AM
Thats you down there on oak grove? i pass this bad boy every time i go out to my buddys house  ==roxs
Post by: Hammerlane on May 06, 2009, 04:17:11 PM
Quote from: Fraser on May 06, 2009, 04:37:59 AM
That would be me.
Post by: Hammerlane on May 07, 2009, 04:38:17 PM
Made a new front driveshaft for it last night..
gotta get the seatbelts completed
top put on..
tranny filled
L hub installed
install new master cyl./bleed brakes
rear pull point welded in.
should be able to wheel this weekend  applaudd
Post by: Hammerlane on May 08, 2009, 05:53:53 PM
Quote from: Hammerlane on May 07, 2009, 04:38:17 PM
top put on..
tranny filled
L hub installed
Finished most of this list last night...
even took Cody for a spin around the house  yeahh
still needs'
trans tunnel pan
check diff fluid (front axle)
weld up brake line supports
fire ext. mounted
changin the rear tires to the swampers (for now)
rebleed the master cyl.
vacume line for brake booster
weld clutch pedal to brake pedal
route trans vent tube into cab
Post by: Jeep Thrills on May 08, 2009, 10:26:33 PM
It was great to meet you the other day,Phil,and thanks for the parts.Post up some pics of the shifter setup when you can,I might have the cover you need.
                                                              Chris
Post by: Hammerlane on May 10, 2009, 07:01:22 PM
Thanks Chris, will do..
Ran it for the first time yesterday  yeahh yeahh
stayed together
dug deep,
ran great.
got 1 more trip thru the hole this morning, just for  p00 &  ==heehee
Post by: Hammerlane on May 12, 2009, 04:42:28 PM
And a pleasant stroll thru the local mud hole..
(http://i21.photobucket.com/albums/b281/hammerlane/tn_100_9900.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/tn_101_0107.jpg)
Post by: ilikebigtrucks on May 13, 2009, 12:08:22 AM
rock on looks like she should have a blast with that i know i would
Post by: Hammerlane on May 16, 2009, 01:47:10 AM
Held it's own..
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0320.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0320.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0321.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0321.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0324.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0324.jpg)
Post by: middleroadBOB on May 17, 2009, 12:26:07 AM
looks like a fun ride
Post by: trogdor48430 on May 22, 2009, 02:34:04 AM
Quote from: middleroadBOB on May 17, 2009, 12:26:07 AM
Post by: betterbeaters on May 22, 2009, 02:12:38 PM
looks like it would be a blast!!!!
Post by: Hammerlane on July 04, 2009, 01:40:28 PM
Couple of pix of me and Cody at the church bog..
Thanks to "The Rock" for a fun day..
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0586.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0586.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0589.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0589.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0590.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0590.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0584.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0584.jpg)
and my favorite
(http://i21.photobucket.com/albums/b281/hammerlane/IMG_0591.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/IMG_0591.jpg)
Post by: JeepinJohn on July 04, 2009, 03:39:43 PM
LOOKED LIKE FUN. NICE JEEP! applaudd
Post by: Hammerlane on September 02, 2009, 04:54:06 PM
Got the last of the major overhauls completed last night..
seals in the adapter for the tcase.. no more trans fluid in the tcase.
Ford 9" rebuild.. new bearings/seals (Thanks Tom)
cut off the brake backing plates and lost the drums..
rebuilt the front drive shaft and greased the whole thing..
took the kids for a spin or 2 around the yard and tested throttle response..
when the lil girl screamed louder than the motor I figured I was in good shape.. ;D
Oh' by the way.. notice the name change.. wonder what the wifey will think  (p.s. she's a redhead too)
Title: Re: Redheaded stepchild
Post by: TopFist on September 10, 2009, 06:46:51 AM
 ==cl...Any time.
Post by: Hammerlane on September 28, 2009, 05:14:43 PM
Well the Moonlight Stompers had their annual "Truck Wars" again this weekend.. attendance was down but a great time was had by all.. 3 day event filled with wheelin and drivin skills.
Camped the whole weekend.. wheeled the snot outta the Jeep..
Spent a couple of nights around the campfire with some beers and friends.
We had:
side by side drag race
barrell race (just like the horses do)
blind race (drivers blindfolded, passanger navigates a course thru the woods) gives some insight on how well you and your wife communicate (P.S. great job dear, we took 1st)
broke for lunch and the kids games: sack race, 3 legged race, musical chairs, tug o war, pina'ta, dizzy race and a watermelon eating contest.
after lunch:
tow rig/trailer race (use your tow rig, have to back up and hook a trailer, then figure 8 around a couple of tires "Backwards")
Chinese fire drill
Best rooster tail
then we opened the pit.. and a small hole in the swamp.. we wheeled well past dark and into the night (Awesome time)
Sunday: everyone up an movin kinda slow, but I opened the pit at the strike of noon and we were off and wheelin again.. wheeled till dark before we broke camp..
I pulled in the drive at 11pm last night.
Carnage:
Ed - front axle (hope your motors ok too)
Dan - Axle shaft
Phil - trans pan
Richard - motor mount
Burgers - starting issues all weekend
Awards:
Dan - 1st place trophy
Ed - 2nd place plaque
Welchy - 3rd place plaque
Kids: got 1st, 2nd, 3rd place ribbons for each game, and a big bag of toys.
Thanks to all the Moonlight Stompers that attended and helped out.. was a great weekend.
Special Thanks to Joe for the use of the property and Bruce for the water truck.
Pix up as soon as my body quits hurtin and I can get them downloaded.
Post by: Fraser on September 28, 2009, 06:01:14 PM
isnt dan the guy w/ that formerly baby blue s-10 on 44's?  he was out at a bog my buddy had at is house last year, was just wondering who it was
Post by: Hammerlane on September 28, 2009, 06:11:58 PM
Quote from: Fraser on September 28, 2009, 06:01:14 PM
Yep, thats him.. Safety Dan.. (he's our safety guy)
Post by: Fraser on September 29, 2009, 07:09:36 AM
Quote from: Hammerlane on September 28, 2009, 06:11:58 PM
ahh, ok  :)
Post by: Eroq on September 29, 2009, 03:13:46 PM
Jeeps lookin good man!
Post by: Hammerlane on September 29, 2009, 04:06:24 PM
Quote from: Eroq on September 29, 2009, 03:13:46 PM
Thanks.. runnin good too, few minor bugs to work out but...
Post by: Gearz on September 30, 2009, 02:01:04 AM
 hippyysm ==thumbsup  Nice stepchild
Post by: Wizzard on October 01, 2009, 11:45:18 AM
good lookin jeep. there will always be something to fix on a jeep...
Post by: Hammerlane on April 03, 2010, 01:32:39 AM
« Reply #49 on: October 01, 2009, 07:45:18 AM »   sleepyy ==doh ==doh woww woww
Wow, been sittin on the trailer that long???   ..... well.. since Tday..
off the trailer and cleaned up, kids were playin in it, gave me a chance to look at the steering/suspension..
Definately time for some TLC..
new bushings, hardware, neighbor made some xtra thick shackles (gotta weld um up yet)
steering arm is next..
still gotta pull the tranny and do the pump seal (don't want no fires w/the kids)
Back window fell out on the way home from Tday... made it all the way home, survived the winter layin on top of the fuel cell
backed it off the trailer and.. well..
so.. now have a nice expanded metal window that I'll bolt on, had to hammer weld 3 small peices together to make it..
turned out pretty nice..
shorty headers
new limiter chains for the front suspension (straps wore out)
Then I can get started on the stuff that needs to get done..  ;D
Post by: Hammerlane on April 27, 2010, 02:26:55 AM
Got it all done, still need a couple of small things done.. trans dipstick, shifter cable and some straight pipe for the exhaust
and it's ready to wheel...
now I should get the wipers workin, build a set of bars for the rear, pinion style brake for the rear at the t-case (no rear brakes sucks when hill climbin) get the fuel cell outta the cab (I hate that) and one of these days I'm gonna loose that rusted out body
read somewhere about a conversion for a D30 front,,
cutting the tubes and installing D44 knuckles and shafts but I'll be damned if I can find the article..
I have an old D30 WT and a D44 but somethings amiss with the shafts.. some reason or another I don't think
44 shafts will fit a 30 carrier  ==hmmm
I want to retain the D30 width, got a locker in it too.. so swappin the 30 for the full 44 is out.
Post by: jdepea02 on April 28, 2010, 01:51:19 PM
i have a bunch of jeep parts email with what u need or come look at them and see what i have  i know i have a solid steel body  aonly a couple spots of rust  a good hood and core support plus lots of interior stuff
Post by: Boggerram87 on April 28, 2010, 02:44:49 PM
Nice Jeep
Post by: BIG TODD on April 28, 2010, 06:04:28 PM
Quote from: Boggerram87 on April 28, 2010, 02:44:49 PM
Nice Jeep
Post by: betterbeaters on April 30, 2010, 08:01:00 PM
I gotta come bogg with you guys again!!! jeep looks good but would look better with a yellow cj5 body lol
Post by: Hammerlane on May 09, 2010, 02:06:49 PM
2 bogs in 2 weekends, fixed the steering shaft in between..
quit hard on me once yesterday (at about 3500 R's just stopped).. thought I hurt it, let it cool down
for an hour or so.. fired right back up and lapped the pit pinned the whole time..
==hmmm  nnnope.. think we're good
had to make a cable adjustment on the shifter so I can hold 1st gear.. now I got no park, but I got everything else I need!!  ==djdj
Post by: betterbeaters on May 10, 2010, 12:05:12 PM
looked good saterday! had fun till the blazer blew up!
Post by: Hammerlane on July 03, 2010, 02:30:44 PM
Just funnin around
(http://i21.photobucket.com/albums/b281/hammerlane/100_0130.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/100_0130.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/100_0131.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/100_0131.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/100_0149.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/100_0149.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/100_0152.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/100_0152.jpg)
(http://i21.photobucket.com/albums/b281/hammerlane/100_0150.jpg) (http://i21.photobucket.com/albums/b281/hammerlane/100_0150.jpg)
Post by: Hammerlane on February 16, 2011, 05:20:33 PM
Well..  had 5 good bogs on it last year.. never broke anything serious.. had a blast..
so.. got invited to snow bog a couple of weeks ago so I fired her up n' brought her up to the garage..
found that the L rear freeze plug was missing... uh oh!   ==doh
I drained it before I parked it.. put a marine plug in, topped it off w/ antifreeze, warmed her up and thought all was good..
gettin ready to load her on the trailer an drip.. drip.. drip.... R side of the motor between #2 & 4 below the head gasket... ==doh ==doh
SON OF A B.................... FYI.. did you know that the 3/8" nipple plugs at the back of a 350 motor will drain the block completely ??? I do.....now!
not leakin bad, but leakin anyway.... hmmmmm...... 350 in the garage... hehehe 454 too!!!
Post by: ProGrade on February 16, 2011, 05:43:22 PM
Looks like you and the kids had a blast...one question, I thought this was your wife's jeep..how come only you drive it? I need to know your secret so i can work out this deal ==lol
Post by: Hammerlane on February 17, 2011, 05:33:27 PM
Quote from: professional grade on February 16, 2011, 05:43:22 PM
She gives me crap about that all the time.. but I'm seriously afraid she'd hurt herself w/it..
Strong arm steering.. she's only 5'4" 110lb redhead..steering wheel would eat her, I'm 6'4" 210lb and I gotta hang on to it good and know when to let go..
So.. I had to drop $3k on another one for her http://wegotmud.com/forum/index.php?topic=55130.0 (http://wegotmud.com/forum/index.php?topic=55130.0)       ==doh
have most of the stuff for hyd. and want to make the conversion.. just need the time.
Post by: OHEARN.2012 on April 15, 2011, 05:52:36 AM
if ya ever decide to get rid of that body or top get aholld of me, do you have doors to? and is it a full cage?
Post by: betterbeaters on April 15, 2011, 01:04:48 PM
you need to get the hydro steering on this so she can drive it!!!!  then we can let the girls beat on the toys while we drink some beers! lol
Post by: Fraser on April 19, 2011, 03:53:50 AM
Quote from: OHEARN.2012 on April 15, 2011, 05:52:36 AM
I'd check the pics on the first page, that tub is pretty much wasted
Post by: Hammerlane on April 19, 2011, 02:30:25 PM
Just made a deal w/ a neighbor on a newer tub (YJ).. should be happenin later this year...
but yea.. that white tub is spent, not much holdin it together...
caging the inside this year as part of the rebuild, soft doors only.. an no! top is not for sale.
