JUST WONDERING WHO'S DAILY DRIVER GETS THE WORSE GAS MILEAGE?
I HAVE A 98 CHEVY Z71 WITH 5INCH'S OF LIFT AND 35'S AND GETTING 9MPG.
Currently driving my rig at 8 mpg but goin to park it soon..
==wgm
04 crew cab 4x4 dually 6 to 10
1997 dodge ram 1500 4x4..6inch lift and 33's....bad cat and exhaust..worn out motor and tranny...6mpg.average..8 on a good day..gets worse and worse as time goes on..needs a rebuild
dont know for sure speedo dont work and i just put a bigger motor in it
The K5 gets 6-8mpg, 4.56's aint so hot on the streets lol the F-150 gets 17
02 chevy hd 6.0 gasser 4:10s 5"lift 33s less than 10 8 towing plus speedo off my 2 mph
1992 3/4 ton 2 wheel drive Chevy 10 mpg
2007 Chevy Colbalt LT 32 mpg
1998 Ford Windstar 25 mpg
1994 Chevy k1500 with 4 inches of lift and 33's
don't know never check because the trip meter is broke.
ha ha thats about the only thing i like about my danger ranger 95 4cyl 5 speed that gets about 25 was told it will get around 30 once i get a tune up and a new air filter
my 76 gets around 6-8 if I am nice to it or 4 if I enjoy the ride!
its not me, over 20 mpg empty. with my F250 17mpg pulling my rig. ==dunno
05 jeep 27 mpg
54 dodge 30 mpg
93 Ford F-150 "Big John" gets 8mpg......
88 ram i was driving got an average 8-12 14 at its best with the 360. got 15 with the 318.
sonomas avg is 26 (19w/ trailer) & the dakota sits pretty much 15-17 no matter how i drive it.
just wait a year or two when the burban hits the road ;D
98 jeep 4.0 GET ABOUT 15 MPG
03 AZTEK dont know dont care it wife s rig
1988 crew cab one ton stock 350 engine gets 5.5 mpg on towing and never had chance to figurempg without towing cuz it always towing something
64 ford never figured out either
02 Durango all wheel drive if I am lucky I get 12 mpg.
All I can say it is not enough!! 78 f150 8ish 78 f250 8ish Bronco 67 No idea 08 Ranger lucky to get 27mpg
6 to 7mpg with my 70. junk carb is part of the problem.
I get about 15-19 in my 08 chevy
Brutus gets 7, no more, usually no less!
That's why I drive Cavvy, 35 not driving nice.
Quote from: Boggin Joe on October 30, 2009, 09:21:44 PM
yup i average about 16-17 mostly all city driving
ill be looking at around 30mpg when im done with my dodge..4x4.6inch lift 33's..it sits at about 6-10 right now depending on the day and if im wearing steal toed boots or not..haha
1994 z71 sas,on 42's 4or 5 mpg race fuel, and 94 50/50 mix
2000 s10 zr2 sas on 36" tires gets maybe 8-10 mpg
The NASA! They have the NASA Crawler-Transporter (thing) that not in MPG!!! It got 125.7 gallons per mile!!! Read rest of the story.
NASA's Crawler-Transporters are the biggest, baddest, most kickass six million pounds of tracked vehicle in the known universe. There are two, Hans and Franz, but I shall refer to the Crawler in the singular as they are identical and it makes it easier mmkay? It's big, it's old, it's damn near Pharaonic. The "Crawler" is actually a platform full of generators and engines resting on 4 tracked "trucks". The height of the Crawler can be adjusted independently between 6 and 8 meters by each of the four trucks. The crawler is rectangular, 40 meters long and 34.5 meters wide, but the cargo contact points are positioned in a square 27 meters to a side
Since words can not be used to adequately describe its dimensions, let us break it down. The four trucks are 3 meters high and 12 meters long with two treads each. Each tread has 57 shoes per track. Each shoe weighs over one ton. This is all just to support the load, not to move it. The moving is done by 16 375 horsepower electric traction motors, two to a tread, four to a truck. These are powered by four 1,000 kilowatt generators in the main body, which are turned by two 2,750 horsepower diesel engines. This is all just to move the thing in one of two directions, forward and backward. Jacking, steering, lighting, ventilation, and the onboard systems are powered by two additional 750 kilowatt generators turned by two more 1,065 horsepower diesel engines. Two additional 150 kw generators are needed to raise and lower the platform. In case you didn't keep tally that's 7630 horsies of Diesel power being made into 5800 kilowatts of electricity.
This thing pokes along at 3 kph, 1.5kph loaded, and gets a full 0 mpg. That's right, 0 mpg. Because when you round 0.007 mpg, it becomes zero. Back on track, this means that the Crawler gets 42 feet per gallon, at 125.7 gallons per mile. It takes about 1,000 gallons to move the Shuttle and MLP between the Vehicle Assembly Building and the launch pad. This drinks from the combined 5,000 gallons of onboard fuel storage. All this makes things hot, so 500 gallons of water circulates through six radiators each with up to a 75 hp pump. The crawler is also said to be the loudest vehicle on earth, even after taking into account it's six 9 foot long 3000 pound mufflers.
The Crawler is controlled from one of two cabs on opposite corners of the Crawler. They don't try to back this thing up, they just reorient themselves and switch control cabins. The crew consists of one driver, four observers advising the driver, and six technicians minding the many systems. When the Crawlers where first used during the Apollo missions, the crew were all actually supplied by the Bendix Commercial Vehicle Systems company, which seems to specialize in heavy trucks, but I can find no data on the current crew. The driver's cabin has the regular instrumentation of gas pedal, brakes, speedometer. air conditioning, two way radio. The ignition process is no simple turning of key. There is a 37 page checklist to be followed that involves charging circuits, pressurizing pnuematic and hydraulic systems, and setting up the generators. But I must wonder, what kind of acceleration does a 6 million pound vehicle get when carrying 12 millions pounds of cargo? Does he just tape the gas pedal to the floor and read the paper until the speedometer jumps from '0' to '1'?
Less than a mile per gallon, but man what a ride!!! 1979 F-250
a=f just took a trip in mine ,got 17 mi. to the gl. a=f
Quote from: TBigLug on October 31, 2009, 02:06:52 AM
I have a 01 z24 cavvy (32+ mpg) that I haven't driven in 4-5 months because I am always on call and have to drive a stupid box truck (7 - 9 mpg) everywhere. Ps. since June 15th when I got the box truck I've put 28,000+ miles on it. Don't do the math it will make you sick.
3+3 you dont drive much.
94 f250 351W gettin between 10 and 14... not awfully bad
the Jeep gets a little over 12mpg right now, needs a tune up...
1984 s-10 8mpg on a good day
94 k1500 ,mild 350 roller motor, turbo 350, 4.56 gears, 9"lift, 38.5 mickey thompson claws-6.5 mpg
88 blazer on 35 tsls and boggers, mild 327, turbo 400,10 bolt and 14ff with 4.10 gears - 7.5 mpg
01 w900 kw, cat c-15, 18 speed, 3.90's pulling a set of super trains @160.000+ lbs 3 mpg , pulling a 7 axle walkfloor now @142,000 to 145,000 lbs i'm up to 3.8mpg!!!!
1964 chevy c20 2 wheel drive,292 6 cyl. 4 spd. 8' stepside 513 gears gets only 10 mpg empty or towing
badass can tow a tank with ==np only 57,000 original miles on it.
1990 F-150 XLT 15 - 17 depending on the mood its in
1995 F-150 XLT Lifted and sitting on 35's........bout 9 - 13 city/highway
1996 chevy dually 454 with 4.56 gears. I get around 6-8mpg
Well i heard today on the news $3.50 a gallon by memorial day...
my d.d. gets 32-35 beating the p00 out of it and close to 40 being nice. My truck gets 16-18 beating on it and 25-28 being nice.
d.d. is 93' geoo prizm 1.6L 5 speed 2wd , truck is 91' gmcc sonoma 2.5L 5 speed 2wd
did I win?
5mpg. City in the k5.....8mpg highway
87 Chevy 4wd don't drive enough know and don't want.
87 Chevy 2wd haven't driven since I got it. Was told by previous owner he was getting 25 on the hwy.
97 Explorer 5.0 awd 20+ hwy 12-15cty. It gets better mileage then my old 4ltr Explorer did.
99 dodge ram 1ton axles 5:13 gears 40inch m16 tires 318 motor 3MPG
oh my i get 6 with the blade on the truck about 9 with it off 410s 35s 6.0 gas k&n cold air induction and no muffler cats only .3" duels to the axel into a 3" single
Quote from: chico on November 10, 2009, 11:28:40 AM
VERY NICE.
My Wagoneer was getting 8-10 before I lifted it. That was with worn out motor and trans, 3.31 gears and 31 inch tires. I dont want to know what it will get with the same motor and trans with 4.10s and 35's. But I am going to guess around the same or worse.
well 8-18 in the monte depending on if i ope up the primary's gotta love q-jet's
my old 89 k with the stock 273's yes 273 and 32's got 8-12 then with the 3/4 ton axle's 410 gear's and 35's bumped it up to 14-16
my 84 c10 befor i broke the rear axle and both ujount's at the same time got 7mpg and that was also with 273's and 235 tire's adn it's only a small block ;D
1978 1/2 ton chevy long box... 9mpg
2009 chevy cobalt... 41 mpg
