On The Trail => 4x4 Safety => Topic started by: monsteram on October 13, 2010, 01:31:16 PM
Title: tow hook question
Post by: monsteram on October 13, 2010, 01:31:16 PM
where can i go to get a good hook that will attach to a toe strap? ive already got a D ring with the reciever shackle, now i just gotta get a hook for the other end of the toe strap but everywhere i go the part where the toe strap would go on and the pin goes through it is to small for the strap to fit through. any answers will help thanks
Title: Re: tow hook question
Post by: Hammerlane on October 13, 2010, 03:47:30 PM
You should not use a "Hook" for recovery.. dangerous and deadly.
a (screw type) clevis is what you need and can be found at TSC.
look here, first post is what you need.. they come in various sizes.  http://wegotmud.com/forum/index.php?topic=14715.0
Post by: catfish on October 13, 2010, 03:49:55 PM
dont atahe tow hook to strap it could come undun and kill soem one, always hook it up wiht aht least 3/4in screw shakel or rapit around its self
Post by: Blazin40s on October 13, 2010, 04:33:54 PM
Not too sure what yer asking, but attaching things to straps is a bad idea.  Attach a reciever front and rear of truck and use shackles on a shackle block or a hitch and put it where the ball would normally go.
Post by: monsteram on October 13, 2010, 04:39:03 PM
http://www.summitracing.com/parts/SMT-29312B/   ive got this on the trailer hitch but idk wat to put on other side of toe strap.  another D ring or?
Post by: monsteram on October 13, 2010, 04:42:58 PM
and that hook has a latch on it im new to the off roading so tryin to learn about the right way to do things
Post by: Hammerlane on October 13, 2010, 05:22:53 PM
Don't sweat the fact that your new to this..  ==np
glad to see your being smart about it and askin ???
now..
1st things 1st..
"Tow straps" are a no-no.. they are for towing, typically do not stretch.. and have hooks on the ends, don't use them for recovery.
a "Recovery strap" will stretch like a rubber band.. it uses that stored energy to help move the stuck vehicle, are generally rated higher (read:stronger) than a tow strap and have loops sewn into the ends (a quality strap will have leather wrap to help protect the loops from fray and damage)
there is a difference..
your reciever setup.. good choice.. the D ring also called a clevis (which is the part that unscrews on this setup) is attached to the "Loop" on a "Recovery strap" and assuming your strap is in good conditon and rated for your rig.. will not release/fall off/slip/slide or generally "let go" of the rig being recovered or the recovery rig (this is the deadly part) and NEVER.. EVER.. hook two straps together with a clevis... people die!.. I know this from personal experience.  Most of us that wheel carry at least 1 clevis, so if you show up w/ the strap and the reciever setup.. we just attach our clevis to your strap, hook it to our "Pull point" and wal-la.. a recovery party in progress.
Check out some of the videos on this site, read some of the other articles in this section, educate yourself before you go spend a chunk of $$.. and yea.. by all means.. ask questions, we'll help           Welcome 2 GotMud?
Post by: monsteram on October 13, 2010, 06:17:57 PM
Ok I must have a recovery strap cuz it didn't come with hooks and I'm pretty sure its rated for 50,000pds. And I ain't got buddies with trucks so I try to meet as many people as possible
Post by: Hammerlane on October 14, 2010, 03:23:27 PM
Quote from: monsteram on October 13, 2010, 06:17:57 PM
Then your on the right path..
Post by: monsteram on October 14, 2010, 05:24:07 PM
so should i be fine with just that d ring or should i get sumthin for the other end also? lol sorry im new to muddin and off road
Post by: Blazin40s on October 14, 2010, 10:59:17 PM
The other end will b hooked to another truck
Post by: Hammerlane on October 15, 2010, 04:02:57 PM
Quote from: monsteram on October 14, 2010, 05:24:07 PM
Nah, the other end is someone else's responsibility.
although clevis's aren't that expensive.
Post by: Mudbuster on October 15, 2010, 04:30:40 PM
Quote from: Hammerlane on October 15, 2010, 04:02:57 PM
x2 plus if you have a spare clevis, and don't like/trust what the other person has at the other end you can tell them that they have to use yours or they can just stay where they are....
Post by: Ranger Dave on October 15, 2010, 10:06:26 PM
what they said above,
and the olney  dumb question, is the one that not  asked.
i think your on the  right path to.  and you got the  best  guy helping ya to.  hang out at some bogs  and  you will find out whats  up with the  straps. and how there hooked
Post by: monsteram on October 16, 2010, 01:16:20 AM
thanks guys it means alot. ill be out at the mounds on sunday so if the club wants to come out feel free and ill find all the good spots
