im wondering if anyone can tell me what jets i need for e85 i got a brand new 750 hp alky carb wanting to run e85 any help if anyone done this and what i need to do thanks
it all depends on your motor
its a 383 sbc 9.5to1 dart heads solid roller cam je pistons hbeam rods forged eagle crank
cam specs and head specs
heads r 208 215 runners cam is 555lift 248dur 108degree sep
e85 runs better with more compression. also have you converted your fuel system over to handle the e85? pumps lines and regulators all have to be able to handle alky or the e85 will corode and or eat them.
at 9.5to 1 why not just run pump gas?
e 85 works well with any compression under 12to 1 and it makes your motor run cooler and it is corrosive but not as bad as many think
it was gonna be blower motor but not no more and e85 is cheap and runs cooler just checking to see
