Projects & Parts => Garage/Tech => Topic started by: t_ank5 on March 17, 2011, 01:06:13 AM
Title: 84 k5 need help with power windows n locks
Post by: t_ank5 on March 17, 2011, 01:06:13 AM
they arent working and i dont know what the fuse is at all or if its a wire connection or what can anyone help out
Title: Re: 84 k5 need help with power windows n locks
Post by: old school truck dude on March 17, 2011, 02:12:01 AM
Hmmm... Got any power to the doors at all? Probably gonna have to pull the interior panels at some point, neither side is working? Is this truck pretty rusty? Was all this stuff workin and just quit all of a sudden recently, or has it been like that for a while? Give a little more background so we can maybe figure out what happened, please  ;D
Post by: Bowtie972 on March 17, 2011, 02:15:22 AM
On the drivers side between the door and the body, slice the rubber boot open and look at wires in there. Very common spot to break because of door opening and closing so much.
Post by: t_ank5 on March 17, 2011, 02:18:35 AM
no power at all seems to maybe be getting a lil on the passenger side. no rust at all i cant remember if they ever went down or not lol
Post by: old school truck dude on March 17, 2011, 02:19:39 AM
Quote from: Bowtie972 on March 17, 2011, 02:15:22 AM
Yup, and if Im not mistaken, the juice goes through them wires right there first before it gets over to the passenger side because the switch on driver door also can control the p/s door and all that
Post by: t_ank5 on March 17, 2011, 02:26:11 AM
but is there a fuse or wires going to the fuse block?
Post by: Bowtie972 on March 17, 2011, 03:10:17 AM
I believe those have a circuit breaker, not a fuse.
Post by: old school truck dude on March 17, 2011, 01:37:38 PM
Quote from: Bowtie972 on March 17, 2011, 03:10:17 AM
Yup. Could be the d/s switch, too - everything goes through it first
Post by: t_ank5 on March 19, 2011, 05:15:26 PM
idk where this p00 is lol
Post by: old school truck dude on March 19, 2011, 08:23:59 PM
Quote from: t_ank5 on March 19, 2011, 05:15:26 PM
The switch is on the driver side door. All the power goes through it 1st. Look at the wires where they leave the truck cab and enter the door, theyre probably broke.
Post by: t_ank5 on March 20, 2011, 02:56:59 PM
i meant the breaker im not a dumbass just not sure switch of 2 are the breaker but ill check it out thanks guys
Post by: Disturban on March 20, 2011, 06:38:44 PM
Quote from: t_ank5 on March 20, 2011, 02:56:59 PM
They do run off a auto reset breaker but that will not be your problem as they never ever go bad.
As others have said check the wires going into the drivers door and driver side switch...it will be one or the other!
Post by: t_ank5 on March 20, 2011, 10:32:41 PM
sweet thanks ill rook into it
Post by: old school truck dude on March 21, 2011, 03:58:49 AM
The breaker is in the fusebox and is a little silver box thing, plugs in just like a fuse. These seldom go bad, but anythings possible..
Post by: OLD SCHOOL on March 23, 2011, 12:32:43 AM
best thing you could do is go buy a test light & start by checking all your fuse with it, then I would prob. pull the door panel & check to make sure you are getting power & grounds to the switches & go from there ?  like stated with the wires in between the body & door
Post by: BigFrank on March 23, 2011, 12:26:13 PM
check the d side switch they can get coroded and loose contact if ya have power to it and it dont work there ya go  we replaced the motors in sams doors and had a bad switch also if the window regulators are all gummed up like most are that will give ya trouble if the motor cant move the movin parts itll kill the motor   ive got some junk doors with windows and non power regulators if yer interested
Post by: buddman (AKA Mick) on March 23, 2011, 04:44:02 PM
Was having the same issue w my  S10 power windows, just got some manual regulators out of a doner,  tired of not being able to roll the windows up when the muds flying and filling up the inside  LOL.
