anyone know about dodge trucks? i got a 94 2500 with a 360/auto, replaced the motor. got everything hooked up right. cant get the coil to spark... ran a hot wire from the battery to the coil, per the wiring diagram. brand new coil. might be bad? fuses and relays are all good...
did ya try jumping the coil with a hot wire like i said ???
Quote from: Eroq on March 30, 2011, 02:42:48 PM
you musta forgot how to read, or you didnt read what i posted... butthead.... loll
Quote from: Le Dude on March 30, 2011, 02:38:31 PM
its a dodge thats the problem
Look up dodge in the dictionary....it says "to avoid" I suggest you take webster's advice...loll
did you check the resistance across the coil?
Just use the gd screwdriver ;D loll
Was it runnin when ya took it apart? ;D
i got some pocket lint, some abc gum and a few mt dew cans ill trade ya for it. lmao
Might not shoulda took it apart... Lotta help today, aint we? yeahh ==ha
there a porcelin pice on the fire wall that has a spring type of thing in it if thats burnt it wont start. it about 4 inches long and 3/8 wide
Quote from: Ranger Dave on March 30, 2011, 11:10:06 PM
Yup, I forgot about that one.. Its usually the culprit .. Also might check the dizzy bushings, if the shaft is wallowing around in there it wont work and they used to be bad about it, had a few dodges like that back in the day before I realized that I was probably better off to ride the bus than own one of those thangs yup, uh huh.. ;D loll
not my dodge, im just tasked with fixing it...
That ballast resistor can look fine and not be worth crap, no idea how to check it
Quote from: old school truck dude on March 31, 2011, 07:11:17 PM
on all the dodges i had when the vechile would not start i would take the wires and tie them together and see if the vechile would start if it did i knew it was time to change the ballist resistor..
No ballast on a 94 or newer
Quote from: Flat_Black on March 31, 2011, 11:02:57 PM
it ran like crap before we pulled the motor. there was a chunk missing from one of the pistons. im thinking its a crank sensor.
