Projects & Parts => Garage/Tech => Topic started by: solid 12 on April 22, 2011, 09:14:18 PM
Title: hydraulic steering pump choice ??
Post by: solid 12 on April 22, 2011, 09:14:18 PM
I am wondering what would be the better way to go with for a pump..right now i have the smaller power steering pump with an external resevior, but i was told i could use an electric pump off of a fork truck..i have never ran hydro steering and know nothing about it so any help would be great!  I plan on buying a 120 amp alternator either way and i was told i would need to run 2 batterys if i go with the electric pump..
Thanks
Title: Re: hydraulic steering pump choice ??
Post by: RaZiN KaNe on April 23, 2011, 01:48:34 AM
i run a stock power steering pump on my hyd set up..... just drilled out the fitting in the pump to allow more flow....never had a problem with it
Post by: 'the DON' on April 23, 2011, 01:50:37 AM
stock pump here with the fork truck orbital valve
Post by: solid 12 on April 23, 2011, 01:53:03 AM
thanks! i will probably run my pump that i got now but didnt know if the electric pump would have been worth the hassel of a 2nd battery and trying to find one
Post by: 'the DON' on April 23, 2011, 01:56:07 AM
i think mudman runs electric pump. most of us run stock
Post by: millser on April 23, 2011, 01:59:57 AM
stock pump bbc on the hoe
Post by: Rollover Herb on April 23, 2011, 03:10:35 AM
Quote from: 'the DON' on April 23, 2011, 01:50:37 AM
X2
Post by: solid 12 on April 23, 2011, 05:59:37 AM
Thanks everyone!  I probably will end up using the pump ive got now
