Projects & Parts => Garage/Tech => Topic started by: Boggen Joe on July 05, 2011, 02:06:38 AM
Title: Noise in a 350
Post by: Boggen Joe on July 05, 2011, 02:06:38 AM
Ok got my motor together Anne got a noise like a lifter tick but louder. I have no clue what it is. I know it is not a lifter, fuel pmp, balancer,.
Has anyone heard of a oil pump be very noisiest? I do have 65psi. At idle
Please I need help
Title: Re: Noise in a 350
Post by: Bowtie972 on July 05, 2011, 02:18:46 AM
I had the bolts on my torque converter loosen up before on my 396 and it sounded like a loud tick/knock
Post by: Boggen Joe on July 05, 2011, 02:23:28 AM
Quote from: Bowtie972 on July 05, 2011, 02:18:46 AM
I run it with out it bolted up also
Post by: OLD SCHOOL on July 05, 2011, 02:48:34 AM
What type of heads are you running?  make sure the pushrods are not hitting the heads   ++peace
Post by: 85cHeavyMetalBogger on July 05, 2011, 08:00:06 AM
wheres it comin from? fly wheel hittn inspection plate on trans..?
Post by: Jjay78 on July 05, 2011, 11:04:38 AM
exhaust tight, have herd a couple sound like lifter ticks before..or rockers hitting the valve covers?
Post by: Boggen Joe on July 05, 2011, 09:14:49 PM
World S/R torker heads. It's a fresh motor. Don't have a inspection cover on it yet. I'm going to change the flex plate tonight.
Can't pinpoint where the noise is coming from
Post by: 73chevytruck on July 06, 2011, 02:33:37 AM
does it sound like its coming from a certain side of the motor, and does it do it all the time or just at higher rpms.
Post by: Boggen Joe on July 06, 2011, 09:58:46 PM
 ++peaceDoes it all time. Can't tell where it's coming from
Post by: RIP_K52007 on July 07, 2011, 01:15:57 AM
Quote from: Boggin Joe on July 06, 2011, 09:58:46 PM
I had a bad bearing in a water pump that made the motor "knock" but that was a 2.5L loll
Post by: MR NASTY on July 07, 2011, 01:27:05 AM
I hear of guys talking about wrist pins making a knocking noise.
Post by: old school truck dude on July 07, 2011, 01:59:24 AM
Pull the plug wires one at a time and put back like youre lookin for a miss. You can shut it off each time, no big deal. If the knock stops or changes when you have that cylinder cancelled, you got trouble for sure. Is it a stroker motor? If its a stroker, could be a clearance issue. Are the bolts that hold the cam sprocket on tight? Dont run it much till you figure out what it is.
Post by: Boggen Joe on July 08, 2011, 10:45:35 PM
I think I figured it out.  I pulled the heads off and it looks like the pistons are hitting the heads right on the cnc Rigel. Like only 5thou. I'm going to grind it and see what happens
Post by: old school truck dude on July 09, 2011, 03:08:12 AM
Grind the head a little to clear? Just go real gentle if you do, water jacket in there somewhere.. Gotta try and do all the chambers the same way much as possible itll work, might still rattle a little bit at higher rpm, just have to wait n see ;D whats a cnc rigel?
Post by: MR NASTY on July 09, 2011, 04:27:51 AM
Be a lot easier just to run a thicker head gasket.
Post by: Jjay78 on July 09, 2011, 11:57:45 AM
Quote from: MR NASTY on July 09, 2011, 04:27:51 AM
agreed,
Post by: old school truck dude on July 09, 2011, 01:16:11 PM
Makes me kinda wonder if the pistons got mushroomed any at all.. Depending on how close the ring grooves are to the spot where the piston was hittin the head, it would also make me wonder if if the ring groove could be pinchin the ring.. If it were mine, Id probably wanna look at that before I ran it again, make sure the rings aint seized up in the grooves..
