Projects & Parts => Garage/Tech => Topic started by: boggers55 on July 29, 2011, 02:01:22 PM
Title: Truck wont start
Post by: boggers55 on July 29, 2011, 02:01:22 PM
well my truck wont start i just replaced the battery it dosent roll over but when i turn the key the windows go down the radio turns on it just dosent want to start.
so what should i do?
Title: Re: Truck wont start
Post by: BUDGETBOGGER03 on July 29, 2011, 02:02:27 PM
does the starter make any noise?
Post by: millser on July 29, 2011, 02:05:25 PM
run a swich and a push button
Post by: boggers55 on July 29, 2011, 02:17:25 PM
Quote from: millser on July 29, 2011, 02:05:25 PM
what u meen ?
Post by: Crazymays77 on July 29, 2011, 02:23:18 PM
U need to see if the starter is working or not. It could be the starter or wiring to the starter. So what he is saying run a momentary switch from the batter to the starter and see if it kicks the starter over if so then u have bad wiring somewhere. If it doesn't kick over then ur starter is bad.
Post by: Crazymays77 on July 29, 2011, 02:24:24 PM
Would help if you told use about the truck year make model anything u done to it that might have caused the problem things like that helps us better to help u.
Post by: BUDGETBOGGER03 on July 29, 2011, 02:27:28 PM
its a 95 dodge ram 2500
Post by: Crazymays77 on July 29, 2011, 02:42:04 PM
Ok. Check the starter. Do u hear a clicking sound when u try to start it? It could because few things. I'm thinking starter or wiring.
Post by: BUDGETBOGGER03 on July 29, 2011, 02:52:33 PM
he said he doesnt hear anything i told him to check his starter wires!
