so im debating if i wanna drop my truck 2 inches and get a set of 31x12.50 boggers and give it a mean look or if i want to drop it 2 inches of susp and put on 2 body and have a dd set of 33x12.50s and a bogger set of 31x12.50...but... and this is a big BUT. loll if i left it droped 2 inches id be able to run my front driveshaft all the time as of now the angle is to much for it and it dont like that to much or if i spend more money i can do the 2 inch susp drop and then do a 2 inch body an still have it at the same hight and be able to run the shaft but it think itll look wierd on 31x12.50 ??? idk let me know what yall think or if ya have any ideas
why don't you leave the suspension alone and drop the case an inch?? the angle on my front shaft was horrible, but after i droped the case an inch it was ok
Id just take the money you thinking of spending and buy a high angle drive shaft for it.
Quote from: MR NASTY on September 07, 2011, 11:02:36 AM
Its got a high angle shaft already for it n t case is droped 2 inches already and the way they have 4.3's set up the drivelines on an angle goin up
Info on truck and modifications would help
Basically its a gmc sonoma sas dana 30 up front witha jeep 8.5 long arm kit it was originally 2 wheel drive it sits on 33's now its got a custom front drive shaft what else ya wanna kno?
What kind of shaft? Ever check out tom woods driveshafts? They make some shafts for very extreme angles
its just a jeep cheroke shaft modified and snaped it again at sticks of romeo. loll but i blew the motor to so i think im just gonna put my nwe motor in and while im doin that just lower it 2 and find some 31x12.50's and call it a day
I didn't see u out there. What color is it? I was in the brown and white k5
i had the sas zr2 with the dual rebel flags on the back i went threw once snaped my front driveshaft within 30 seconds then just played around in 2wheel the rest of the time
Didn't even see u loll
Loll its kind of understandable their was 1050 plus people their
