Projects & Parts => Garage/Tech => Topic started by: KORNBREAD on September 22, 2011, 02:19:13 PM
Title: t-case/350 trans combo
Post by: KORNBREAD on September 22, 2011, 02:19:13 PM
what t-case's out there will bolt right up to a 350 turbo trans?? Im getting a 79 Chevy 1/2 ton that someone put a 700r4 in and fried it. I want to go back to a 350 turbo but i dont want the 203 case and finding the 205 with adapter for the 350th is harder to find and pricey.
Title: Re: t-case/350 trans combo
Post by: J.C. on September 22, 2011, 02:23:14 PM
350s had a 208, 81 was the only year i think. being only 1 year, i think they would be harder to find? you could put a set of lockouts on the front depending on what axle it is, if ya used a 203.
Post by: KORNBREAD on September 22, 2011, 03:20:46 PM
Yeah the truck has front lockout already. I dont want to run the 203 because there so damn heavy and (not a huge fan). Im restoring this truck when I get and its not going to bogged ( i will play some here and there) so a 203 would be fine but i just dont like them. I was hoping to do a lighter case like the 208 or so.
Post by: Captn. J on September 22, 2011, 05:17:31 PM
208 or the 241
Post by: KORNBREAD on September 22, 2011, 05:31:35 PM
the 241 will bolt up?? what year 241's
Post by: 7387chevynut on September 22, 2011, 08:09:23 PM
208 or 241 will NOT bolt right up...............because your 350 turbo is the 1970-1980 style..........meaning it has a SHORT rear tailshaft, and it was only meant to work with the 203 (which had a thin adaptor plate)..............or the NP205 (which used the thicker adaptor...but with a splined coupler inside of it).
GM did offer the NP208 behind the 350 turbo, but it was only in the 1981 model year.........and GM had to modify the tailshaft of the 350 to make that work............AKA>....they made the shaft longer..........so it would run through the adaptor.....and straight into the T-case..............this design did away with the idea of a (thin) adaptor plate............or using a (splined coupler) inside the adaptor housing.
Now you can modify a 1970-1980 350 turbo to bolt up to a 208 ( contact Mudbuster on here, he's done this already). By using a 350 turbo NP203 adaptor, with a little welding, and drilling some extra holes.....it will work. The other option you have......is getting a 2wd 350 turbo shaft....which is longer, and have it cut down to length, or keep it as is and run a aluminum spacer in between to compensate for that extra shaft length.
Other options......are     KEEP your 700R4......which should already have the NP208 behind it.......and have it rebuilt.......and have the advantage of a lower 1st gear of 3.06 and Over Drive.
Or get a 203 (very common to find) and install a part time if doesnt already have one.
Or find a NP205 for your 305 turbo, which 1970-73 (74-75 )  had fixed yokes, or the 1980 version which was slip yoke rear, and they tend to be pricey 150/250 for complete set up.
I think your cheapest route.......is to have (Mudbuster) make up a adaptor plate for you......using a 203 adaptor plate from a 350 turbo/203 combo.
Post by: Captn. J on September 22, 2011, 11:18:59 PM
like he said above mudbuster gave me one of the adapter that he made to fit a 208 behind a 350 that orginally had 203 .... i m in burton and u re welcome to come n look at my set up...  it use the 203 adapter   few holes drilled and  it works for me
Post by: Captn. J on September 22, 2011, 11:20:16 PM
it all also depend the tailshaft of your 350
Post by: KORNBREAD on September 23, 2011, 12:12:52 AM
I want to run a 700r4. I keep getting told I need a switch to hit to lock up the converter, which makes no sense because thats what the detent cable is for. All my older 80's carbed chevys never needed a switch. they had the detent hooked up to the carb. am I missing something??
Post by: Captn. J on September 23, 2011, 12:28:12 AM
u re confusing us   on  top u said u wanna  run 350  and now u re saying u wanna run a 700r4?
Post by: KORNBREAD on September 23, 2011, 12:55:48 AM
I wanted to run the 350th but if I cant find the t-case I want with out chasing down all these special adapters then ill be going to a 700r4 so I can have the light aluminum t-case. So there thats straightened out and back to anyone who can help with the detent/rv cable for the 700. lol
Post by: J.C. on September 23, 2011, 02:26:42 AM
the switch you are talking about "locks" the converter in for better gas mileage. detent cable controls when the trans downshifts. in the electronic trans they use the throttle position sensor, TPS, instead of a cable. mudman could rebuild that trans quick and cheap... thats another option.
Post by: RIP_K52007 on September 23, 2011, 02:32:19 AM
the 700r4 is suposed to have the convertor locked at cruising speed, and without the lock they do run hot, not really good for them. They work, just shorter lifespan.
i'd drop a nv3500 in it and be done with it :P
Post by: RIP_K52007 on September 23, 2011, 02:35:54 AM
http://wegotmud.com/forum/index.php?topic=69149.0;topicseen (http://wegotmud.com/forum/index.php?topic=69149.0;topicseen)
Post by: KORNBREAD on September 23, 2011, 11:51:56 AM
I know what the lock up dose on the trans, but I dont remember my older 80's chevys having that plug. I remember the detent/tv cable but thats it. (God its been a long time sense ive messed with the 700)
Post by: KORNBREAD on September 23, 2011, 11:53:03 AM
Quote from: lilred on September 23, 2011, 02:35:54 AM
Thanks man but $250 is a lot of cash for a "not sure how it runs" trans.
Post by: J.C. on September 23, 2011, 11:54:28 AM
Quote from: KORNBREAD on September 23, 2011, 11:53:03 AM
ill sell ya a 700 core for $50. and i guarantee it wont work. ++peace
Post by: KORNBREAD on September 23, 2011, 12:01:01 PM
Quote from: Le Dude on September 23, 2011, 11:54:28 AM
==ha
Post by: KORNBREAD on September 23, 2011, 01:23:38 PM
Think Im just going to run the 350/203 set up. More I think of it makes more sense. Trucks just going to be a part time dd/work horse. thanks for the help guys!
Post by: Squirell on September 23, 2011, 03:01:45 PM
Take a 350 to mudman and tell him to put the 208 kit in it. You will get a 4 in aluminum spacer and then just need the adapter that comes on a 208 and by.doing it this way you drive shafts stay the same length
Post by: Cannaert on September 23, 2011, 03:02:49 PM
A 208 will bolt up to a 350 as along as you have right adapter (4bolt to 6 bolt) and the right out put shaft spline count.
I had a older 350 that I brought that came with a 208 on it from the PO.
You have options out there.  You can Drop the big bucks on a 205. Keep the good old boat anchor 203 get the part time kit for it.  Run a 208 or a PS drop 241 from a SAS Suburban.
Post by: KORNBREAD on September 23, 2011, 03:39:44 PM
HHMMMMM....Im gonna have to talk to some people to see what they will charge to build my 350 to take a 208.
Post by: Jjay78 on September 24, 2011, 01:56:56 AM
i got both set up's your talking about, and they both have their pluses.. the 350/203 has a lil more simplicity and you get a 2 low option.. but the 700/208 combo gets you a lot more gearing and better cruseing capabilities... you just have to set the detent right, and as for the lockup you don't have to have it, but if you want it all you gotta do is hook up the plug..with one side to a switched 30amp hot and the other to a ground and boom ya got lockup on demand
Post by: old school truck dude on October 02, 2011, 05:03:52 PM
Quote from: Cannaert on September 23, 2011, 03:02:49 PM
Just about anything you do to a 203 requires it to come completely apart and it has several hundred needle bearings in it. Youve really got to know what youre doin to put the part-time kit in it.
Post by: ProGrade on October 03, 2011, 02:25:30 AM
Quote from: 7387chevynut on September 22, 2011, 08:09:23 PM
according to my RPO codes my 87 has a 350 with a 208....behind a tbi 305....defies everything i've read about 208's behind 350's but its true.
Post by: 7387chevynut on October 03, 2011, 04:39:54 PM
Quote from: ProGrade on October 03, 2011, 02:25:30 AM
Anything is possible.........but I go with GM service manuals and other manuals, and they all say 1981 was the last year GM used the 350 turbo in their 4x4's. Because it was replaced by the 700R4
Maybe your truck was a special order option, or despite the RPO code (provided its not an error) that 208 and 350 turbo could have been swapped in by the previous owner who had troubles with his 700R4/208 combo that 98% of 1987 1/2 tons would have come with.
Post by: betterbeaters on October 03, 2011, 05:10:38 PM
if you want a 350 that had a 208 I'll trade ya for one with a 205/203... or if you wanna buy a 205 I got one with adaptor and everything $350
