Projects & Parts => Garage/Tech => Topic started by: BAD APPLE on September 30, 2011, 03:23:40 PM
Title: more RPM
Post by: BAD APPLE on September 30, 2011, 03:23:40 PM
Does any body have some quick easy tips to. Squeeze a few more R's so I can keep running third gear in my bogger, right now I can run between 5300-5500 rpm in third but would like to be able to get closer to 6000 rpm, I ordered a tune up(new distributer, plugs and wires) because it breaks up a little on the top end so I'm sure that will help to get rid of it and I am also gunna jet up the carb a little. So does anyone have any tips to help me out thanks
Title: Re: more RPM
Post by: Blake Scheuneman on September 30, 2011, 03:31:45 PM
Ignition
Title: Re: more RPM
Post by: BAD APPLE on September 30, 2011, 03:34:01 PM
Its a newer msd with a soft touch rev limiter so I should be good there
Title: Re: more RPM
Post by: J.C. on September 30, 2011, 03:35:36 PM
valvetrain.
Title: Re: more RPM
Post by: bigmud44 on September 30, 2011, 03:56:05 PM
if you have solid cam play with valve lash up or down .002 @ time
Title: Re: more RPM
Post by: betterbeaters on September 30, 2011, 08:48:23 PM
call muscle motors 517-482-4900... give lote of money and say I want 8500 3rd gear hi range all day! they will hook you up! lmfao
Quote from: bigmud44 on September 30, 2011, 03:56:05 PM
this is what I would try...
Title: Re: more RPM
Post by: RaZiN KaNe on September 30, 2011, 09:46:43 PM
Quote from: Le Dude on September 30, 2011, 03:35:36 PM
valvetrain.
solid roller....
Title: Re: more RPM
Post by: hot rod heep on September 30, 2011, 11:12:34 PM
Quote from: betterbeaters on September 30, 2011, 08:48:23 PM
yes we will   lol
Title: Re: more RPM
Post by: BAD APPLE on September 30, 2011, 11:50:28 PM
I don't know about 8500 third gear I range, sounds hard on trannys and I already have problems with those but I will be happy with 6000 third gear low range
Title: Re: more RPM
Post by: 4x4xdodgeman on October 01, 2011, 12:28:02 AM
maybe need to tell us what you have for a motor/trans, converter, tcase,gears,tires.
Title: Re: more RPM
Post by: BAD APPLE on October 01, 2011, 12:33:25 AM
462big block Chevy 350/208 3500 stall converter 4:10 front gears with 40in tires 4:56 rear
With 44's
Title: Re: more RPM
Post by: randycrane79 on October 01, 2011, 03:06:29 AM
id try ignition if msd is ok then i d jet carb down lean motors are more power then rich motors ....what carb ya got ?
Title: Re: more RPM
Post by: betterbeaters on October 01, 2011, 04:26:33 PM
steal your dads motor! lol
Title: Re: more RPM
Post by: BAD APPLE on October 01, 2011, 10:18:25 PM
Quote from: 4x4xdodgeman on October 01, 2011, 12:28:02 AM
Quote from: erikmud on October 01, 2011, 12:33:25 AM
With 44's
there ya go theres the specs so what kind of helpfull info do you have
Title: Re: more RPM
Post by: BAD APPLE on October 01, 2011, 10:19:27 PM
Quote from: betterbeaters on October 01, 2011, 04:26:33 PM
i think he would notice if it was missing
Title: Re: more RPM
Post by: betterbeaters on October 02, 2011, 01:27:29 AM
Quote from: erikmud on October 01, 2011, 10:19:27 PM
I keep trying to help ya! lol
Title: Re: more RPM
Post by: old school truck dude on October 02, 2011, 04:45:08 PM
FREE HORSEPOWER AND EXTRA RPM: Key off, driver in driver seat - mash gas pedal all the way to the floor and hold. Have your buddy look straight down into the carb and make sure it's opening all the way. Many people have been quite surpised at what they see when they perform this check.  ;D
Title: Re: more RPM
Post by: BAD APPLE on October 03, 2011, 12:40:59 PM
Quote from: old school truck dude on October 02, 2011, 04:45:08 PM
its open all the way
Title: Re: more RPM
Post by: betterbeaters on October 03, 2011, 12:50:43 PM
mabye try timing? or a big ass blue bottle!
Title: Re: more RPM
Post by: BAD APPLE on October 03, 2011, 12:53:24 PM
Quote from: betterbeaters on October 03, 2011, 12:50:43 PM
its timed according to a timing light, and i do have all the stuff to spray it, but that p00 is expensive, plus it would be all gone befor the day is half way over
Title: Re: more RPM
Post by: mudbillyredneck on October 03, 2011, 02:56:31 PM
 advance springs on dizzy , to tight or loose ?
