i wanna drain my dd 's antifreeze... i m sure mine use dexcool or whatever color that is ... not green but was wondering if i can use just antifreeze 50/50 after i drain? to be exact it s a 2003 ford F-150 w 5.4
read the jug a lot of it is ok to use now it was not ok at first but i think they changed it all now to be compatable ?
thats what i m thinking too...
i know most of them are interchangeable now, but some of th eolder stuff doesn't mix well....
i dont know abought the 5.4 but i know the 6.0 power stroke has to have a difrent kind... and i think dexcool is gm olny ???
Dexcool is only gm, and its pink/orange use the yellow antifreeze, compatable with all types.
Quote from: rangerwheelinmike on October 01, 2011, 02:04:25 AM
The diesels have a different kind to help prevent pitting in the outside of the colant jacket around the cylinders. I think the orangeish color stuff is what fords use, should beable to look it up on autozones website..
Quote from: Captn. J on October 01, 2011, 01:24:27 AM
use the extended life stuff its compatible with both
shd i have a shop do it or shd i do it myself and save myself $?
Quote from: Captn. J on October 05, 2011, 07:15:34 PM
open the petcock. drain some water. pour anti-freeze in. get anti-freeze meter, $2-3 at the zone,, then adjust mixture to suit.
