Does anyone make a selectable locker for the Chevy 10 bolt IFS or am I looking at doing a SAS if I want a selectable locker? Also what is the spline count and ring gear size in my 1991 IFS 10 bolt?
Keep the tire size in check if you are doing a locker in a full size with 1/2 axles.
For what vehicle? I thought you were buying a 2wd newer suburban?
Quote from: 7387chevynut on October 14, 2011, 03:21:53 AM
2wd...roflmao! No I was looking for a 4x4 3/4 ton Burban but I ended up finding this diamond in the rough, I got all the info I need and am probably going to do a straight axle conversion in the spring. http://wegotmud.com/forum/index.php?topic=69509.0 (http://wegotmud.com/forum/index.php?topic=69509.0)
