i have a 93 jeep cherokee with a 4.0.. i have 7.5 in of lift but i am looking to do a long arm kit on the front axle but i dont have the money to go out and buy the conversion kit.. anyone have any tricks to building a long arm kit or know anyone that has one for sale for cheap... also transfer case seal on the drive shaft dont seal.. i have bought several different jeep rear main seals.. none of them keep the fluid in. none of them fit right around my rear shaft.. any ideas on a fix?
Quote from: BLZNBIG on October 26, 2011, 01:18:44 AM
your shaft is too small ==roll j/k couldn't resist.
is your bearing on the output shaft for your t-case bad? I'd check it for play, you'll never seal otherwise.
Quote from: ProGrade on October 26, 2011, 03:14:07 AM
or the seal is whomped... have had that problem too loll
