Projects & Parts => Garage/Tech => Topic started by: Colorado on December 22, 2011, 11:36:06 PM
Title: For those willing to look, 92 CPI 4.3 issues
Post by: Colorado on December 22, 2011, 11:36:06 PM
My blazer has the first year of the vortec intake, central port 4.3. The first issue was lack of power so I replaced the plenum fuel line and put in a newer fuel reguator. Then it became hard starting. It would
crank w/o firing. Well I have plugs that fire and injects gas fine. But now it will barely start on starting fluid. If it does it will idle fine, but sputter in gear then die before needing more fluid.
It's gotten to the point that it won't even rev without backfiring. I took the plenum off and starting fluid fires back out the intake tunnels.
   This said, I think the timing is done. Any idears?
Thank you for responding if you do. Ryan.
Title: Re: For those willing to look, 92 CPI 4.3 issues
Post by: scooterbob on December 22, 2011, 11:48:10 PM
dont want sound dumb, but have u removed the cat. converter yet?
Post by: Colorado on December 22, 2011, 11:52:19 PM
Not a dumb question. The cat was gone when I bought it. It's runnin straight piped exhaust with one muffler. It ran like p00 before the exhaust was done. I thought good exhaust would fix this since it was bad beforehand. The Y pipe has a realllly small leak but nothing horrible. I'm told it's timing. But  ==dunno
Post by: scooterbob on December 22, 2011, 11:54:31 PM
how much fuel pressure?  could be timing though
Post by: Colorado on December 23, 2011, 12:01:58 AM
I don't know the fuel pressure  but the backfiring I know has nothing to do with the pressure. Also, I'm told if the timing is fried then the motor needs rebuilding.
Post by: RIP_K52007 on December 23, 2011, 12:03:28 AM
them pletums are known to go bad. but i doubt thats the problem, maybe try changing the EGR valve in there while you got it apart.
Post by: Colorado on December 23, 2011, 12:05:53 AM
I don't remember it breaking but a tab on the EGR piece snapped so I gotta get another one.
Post by: mudbrat71 on December 23, 2011, 03:08:31 PM
check fuel pressure should be like  45 psi that will cause lean back fire
Post by: J.C. on December 23, 2011, 03:10:08 PM
Quote from: mudbrat71 on December 23, 2011, 03:08:31 PM
needs 62 to start and 59 i think to run? i could be wrong tho
Post by: Chevy Racer on December 24, 2011, 01:18:51 AM
Quote from: J.C. on December 23, 2011, 03:10:08 PM
I'm thinking in the 60 PSI range too.  Also I think I got an EGR that will work for ya.  I'll look around.  They are like $90 new.  Ask me how I know that.  LOL
Post by: ProGrade on December 24, 2011, 05:57:17 AM
did you check the distributer gear? wear or damage is fairly common and will make it run like p00  if you didn't already check plugs and wires too.
Post by: rangerwheelinmike on December 24, 2011, 06:00:36 AM
did you change the coil? rember how i riged that one on i at the mounds when the other one blew up? lol
Post by: BigFrank on December 24, 2011, 01:03:47 PM
Quote from: ProGrade on December 24, 2011, 05:57:17 AM
check for slop or end play between the gear andend of it those 4.3 can be fussy on the timing  being just right   id think a fuel pressure issue is most likely trhe cause
Post by: Colorado on December 24, 2011, 04:34:09 PM
Quote from: Chevy Racer on December 24, 2011, 01:18:51 AM
So how do ya know that? loll I can even come get it from ya. (maybe cheaper?)
The distributor seemed to have no play this summer. It's got a tested good ICM, with new cap. Wires didn't look bad but I have to assume they are old.
Quote from: rangerwheelinmike on December 24, 2011, 06:00:36 AM
It's still got the coil on that we rigged. It even tries to fire without being properly grounded.
And BIGFRANK, I think yer right. Next step is checking pressure. The pump is NOT new at all. I'm convinced the timing is shot which I'm told if that's the case the whole engine needs rebuilding = not worth it.
Post by: rangerwheelinmike on December 24, 2011, 07:15:17 PM
you need to ground that coil better its not even tight
Post by: randycrane79 on December 24, 2011, 07:47:17 PM
needs 60 psi of fuel preasure to start and if its not there it will send you all over the place to find it check ya fuel preasure before ya do anything
Post by: Colorado on December 24, 2011, 09:10:10 PM
It was grounded tightly and still didn't run mikey and yes I plan to do a compression AND fuel test after Christmas even though I'm also told fuel won't affect it.
==thanks everyone for the help.
Post by: RIP_K52007 on December 25, 2011, 04:50:55 PM
fuel will affect it dude... it runs on gas ==roll
Post by: monsterjeep on December 26, 2011, 12:00:36 AM
It sounds stupid but if its got a w vin code the temp sensor on the drivers side haed is bad it makes it hard to start and back fires because its not reading the right fuel pressure thru the computer i saw a couple of them at the shop do it If that helps
Post by: Colorado on December 26, 2011, 06:17:16 PM
Funny you say that cuz I've never tried the temp. sensor AND I don't have a fuel (another story) or temp. reading..... TWO gage clusters later.
My opinion, 4.3's go forever pretty much and I can't picture the timing gone at (purchased miles of) 125k.
And I (still) agree Derik. Anything is poss. with engines.
Post by: doughchvy1 on December 26, 2011, 08:27:34 PM
Colorado, I had a 95 that would do that. i put alot into mine trying to find the problem out and it ended up being the temp sensor along with the O2 sensor they were reading oppisite of each other which was throwing the timing all over the place.
Post by: Colorado on December 26, 2011, 08:45:03 PM
That's crazy p00. Well I hope just replacing the temp. sensor does the trick then. Far as I know the O2 sensor is factory.
==thanks
Post by: Squirell on December 27, 2011, 01:55:11 AM
sounds like a fuel pump.....gf blazer did the same thing. changed the fuel pump and its fine now
Post by: Colorado on January 16, 2012, 12:12:29 AM
That would also be cool with me. Well the fuel pressure is about 42 and the compression is low. 90-120 most cylinders. Just put in new injectors and it still only starts on starting fluid and dies once ya touch the gas. Next step in coolant sensor.  :(
Post by: Chevy Racer on January 16, 2012, 12:58:24 AM
42 PSI?  Needs a little more than that.  I would go with a new pump.
Post by: Colorado on January 16, 2012, 02:02:21 AM
Ya priming it's about 60ish and running it bounces around 42. Really don't wanna do a pump but apparently that's the problem. Gotta see what the book says. Guess I'll try a coolant sensor too.
Post by: xjs3667 on January 16, 2012, 02:12:04 AM
Imo  stop throwing parts at it and hoping one of them will work...very costly, unless you have the money then go ahead, but test the parts before you replace get a scanner hooked up to and see if cts is reading correctly, your fuel psi is low dont just assume its the pump, check filter and psi before filter, and also when you checked fuel pressure what was the pressure after pump primed with key on engine off. CTS could be throwing the timing off but then you need to find out about fuel psi problem
Post by: xjs3667 on January 16, 2012, 02:19:03 AM
prime fuel psi key on Engine off-  60psi
Running psi- no less than 54 psi
clogged line, filter, or sock on pump can cause 10- 15 psi drop
Post by: Colorado on January 16, 2012, 02:42:25 AM
To my knowledge you can't connect a scanner to OBD1. It had a code on and off this summer when running but it seems gone. I put on a new inline bottle type filter when I dropped the tank and tried to fix my lack of fuel gage issue. The intank sock filter didn't look plugged at all. Dunno how to check pressure BEFORE inline filter unless I put in a filter delete fuel line....but that one was new....
Post by: Buck on January 16, 2012, 03:05:18 AM
the spiders go bad in them  alot under the intake  check them 25 50 bucks at  junk yard
Post by: xjs3667 on January 16, 2012, 03:06:50 AM
I have a scanner that hooks up and will control computer functions as well as read codes, but easy way to test cts pull it out and hook up volt/ohm meter to it, check for oem specs.   To check psi before filter- fuel pressure tester should have an adapter that will thread into fuel line or a quick connect, If not easy to make one, self explanatory.  ;D
Post by: Colorado on January 16, 2012, 03:54:34 AM
Quote from: Buck on January 16, 2012, 03:05:18 AM
I just installed brand new injector poppets and put in new spider lines (both) this summer. With a newer used regulator.
My question is, does the computer read the cts in open(I think it is)  loop (a day of not running)???
Post by: xjs3667 on January 16, 2012, 04:20:08 AM
O2 senosor is read in open/ closed loop
Cts is not its consntly read and adjust fuel rate per temp reading it sends to computer   its kinda like a choke on a carb   its the only way for fuel injection to choke engine     ie cts is broke and is telling computer engine is 800 degrees when its actually 45degrees it would adjust fuel and timing to be crazy lean and vice versa
Post by: Colorado on January 17, 2012, 02:31:31 PM
Well this morning I tested the pressure on our 98 Safari and the fuel pressure never goes below 57-8 and never over 62 so everyone who said 60 is right. So guess F.P. is my issue.  I have a buddy who still says it's timing but this shows itself..   ==doh
Post by: Colorado on February 18, 2012, 11:27:33 PM
Replaced the fuel pump with a Ebay special and it runs great now. ==thanks everyone.
Post by: Jthomas on February 21, 2012, 12:02:33 AM
idk if this is your prob, but it happend to me.
on the fuel pump there is a bag filter that goes on the end of it. well the bag filter came appart and got sucked up in to the pump. it didnt completly stop the pump, but stopped the flow, a lot. so i would backfire under load, and just ran like p00.
hope this is your problem, its an easy fix. wish ya luck.
Post by: Jjay78 on February 21, 2012, 04:58:35 AM
did you check the dizzy gear?? neighbor had a late 90's 4.3 in an extended cab that ran great till one morning we was heading to pick up his old lady when her car died on her, well 1/4 mile down the road he blew off a couple teeth on the dizzy gear and we were walking
Post by: Colorado on February 21, 2012, 12:56:39 PM
JThomas :I replaced the sock filter with the new one that came with the new pump and I checked to make sure it was snug and on all the way.
Jay: I checked all that and it's nice and tight.
Post by: Dirt Worm on February 21, 2012, 06:29:55 PM
Mass air flow or map sensor would cause same symptoms, sounds like same thing my 97 jimmy was doin
Post by: xjs3667 on February 21, 2012, 06:41:03 PM
looks like no one reads thru the thread.........
good to hear you got it runnin good colorado.
glad I could help  ;D
