This project started early last spring, I had sold my 1 tons and bought a set of Rockwell 2.5 tons. Then I had surgery on my shoulder and everything went on hold. I couldnt physically work on it and really couldnt afford to finish it. I went back to work at the end of August, and had a whole pile of insulation that needed to be put up in barn before winter, and the furnace installed. When I had fist started the project I went down and visited Dave, (wildtime) and bought a bunch of parts. Now its finally time to finish this project. I have 8" Superlift springs already, added 6" spring perches to the axles. I did get those welded on the other day, and got my U bolts made. Once I get my trans and T case back in and can see driveshaft angles, i have to make some shims to tilt the axles up. Ive got to make shock mounts, redo rear ladder bars, make a torque bar for the front axle. Im goin with Hydraulic steering also. and rear pinion brake. Planning on keeping the 44" Boggers, 468 BBC, TH350/NP241. Maybe upgrade Trans/T case later.
More pics.
cool
==kp Sweet Rig!!!!
Lookin great!! Can't wait for it to go to tgw in the spring
very nice truck!
one day i hope to build me a big ole Rockwell rig. keep the pics coming
Thanks guys, probably be next week before i make anymore real progress. I am hoping to get the trans back in this week. Another delay, had to put head gaskets on my kids truck. I am hoping to take it to TGW in May, id like to make a trial run at the mounds before that, a little closer to spring. ;D
ill go to the mounds with you i want to see this run . looks good
Quote from: 'the DON' on December 27, 2011, 09:58:17 PM
Sweet!
applaudd
looks good tim
Thanks Marshall!
Hell yeah, lookin good Tim, its a monster for sure! Im sure it will impress, it always does! I will have to stop by and check this out,
Thanks guys! Nothing really worth takin pics of, but I did get the trans/Tcase back in, mocked up the driveshafts. Lookin like im gonna have to lenghten both of em. At least I can tell now how much shimming I have to do to the rear axle. When I get some more parts installed Ill get pics. ==wgm
Lookin good
sweet set up looking to see it in action
==cl
Makin some progress. I couldnt get the Pinion angle i liked, so i opted for the shackle flip & longer shackles. I added a smaller shim and im happy now with it. Did some frame tieing in the back, 2 pieces of
3 1/2" sq tube between frame rails, and connected everything all the way back to the bumper w/ 2 x 2 x 1/4" sq tube. To save some $$, I dropped down the rear shocks instead of buying longer ones. Rear ladder bars are done. I fabbed my own helmet for the front axle to mount my front torque bar to also. I also dropped down the front spring mounts 4". So with susp and body lift its gonna have around 21' - 22" of total lift. ;D Next up is Hydro steering and pinion brake.
A few more pics
Lookin great Tim! its gonna be big!
Sweet!
==awesome those spring mounts look good applaudd applaudd applaudd
awsome truck
==cl project, but i did see somthing you might want to remedy. on the front axle drivers side i see you put your gusset tube on the inside, from my point of view you might want to put another one on the out side or move it to the out side. because if somthing did happen in the front it might start to lean to the driver side or break in that direction. but like i said ==cl project it will be really cool to see it in person if you or me happen to be at the same bog.
==roxx ==wrenchinbanana Keep the wrenches flying. Looking good!
Quote from: OHEARN.2012 on January 25, 2012, 04:01:05 PM
Quote from: Bowtie972 on January 21, 2012, 07:44:53 PM
A few more pics
that for axle wrap?
Yup, With leafs on the front axle you have to come from the bumper and go back ward.
Quote from: 390JOE on January 25, 2012, 10:50:50 AM
I was Thinking about adding one there, not sure yet. The blocks are completely welded to the housing also. Alot of trucks Ive seen online w/ leafs dont have the gusset. I appreciate the comment though. This is my first rockwell build and its definitely a learning experience. I know 1 thing, Rockwells are cheap, but theres nothing cheap about puttin em in, and I didnt even 4 link it.
Thanks everyone for the comments, Got alot done monday, then i had a couple days of training classes at work so ill be back on it thurs. Should have some new pics this weekend, hopefully on rollers.
Quote from: Bowtie972 on January 26, 2012, 12:19:08 AM
A few more pics
that for axle wrap?
u have to go from the bumper?
If you have a hitch in front, or HD bumper you can drop a bracket down from either. I used 4" sq tube to drop my spring hangers down, so i welded tabs on the bottom of that for mine. Either way, but it has to come from front of truck and toward rear.
Quote from: Bowtie972 on January 26, 2012, 03:02:30 AM
I got about same setup as u in front I didnt know it had to cone from front I thought u could do ladder bars
Quote from: OHEARN.2012 on January 26, 2012, 03:50:56 AM
With a 4 link you can come from center of truck forward. With leafs ive learned, Thanks Rollover Herb, that if come from the center forward the shackle cant flex and you will break your main leaf.
Progress
Up on Rollers! Finally!
badazz! really gonna look sweet with big tires on it!
Look gr8 man, glad to see it comin together
looks great Tim! nice job as always!
Thanks guys for the comments! Now if i could find a decent body for it, or do some major body repair. That proboably wont happen this winter though. Too many other projects lined up waiting to come in the barn. lol
;D Nice !
==kp Coming right along and looking great man! Sweet Rig!
==wgm
==kp 8)
Gettin closer. Stripped all the old brake and fuel lines off the frame. Ran a new brake line and finished the pinion brake. Got the hydro steering all done. Next up is a new steel fuel line and finish hooking trans stuff back up. Then redo the driveshafts and loops for both of em. Hopefully next week it will be rollin outta the garage! ;D
==band ==djdj ==rockbanana
Quote from: Gearz on February 02, 2012, 03:00:35 AM
built it a second time, and still beat GEARZ's out of the barn , lmao!!
Does the concept of running the torque bar to the front work with the rear? As in running from rear axle to rear of truck?
No the rear is like regular ladder bars, from the middle of truck to the rear. Cuz your flexible shackle is in back.
Looks sweet.... are you going to run boggers or upgrade to tractors
Quote from: Bowtie972 on February 02, 2012, 01:48:25 PM
Ahh didn't think about that I need to cone check this out and get sone ideas on rocks you doing any tear down work to them?
Yea i tore them all down already, welded the spiders, new seals and boots. Flipped the rear hubs out to match the front too.
Quote from: Bowtie972 on February 02, 2012, 04:38:38 PM
if ya need any help working on them then call me up
H
Quote from: OHEARN.2012 on February 02, 2012, 06:26:56 PM
Ok. Are you planning on runnin to 2.5's?
very cool bud
LOOKING GOOD AND OC THATS NOT VERY NICE TALKING ABOUT GEARZS LIKE THAT LOL
Quote from: Orangecrush on February 02, 2012, 03:28:29 AM
LMAO. ==kk
Quote from: puddlejumper on February 02, 2012, 01:57:27 PM
Thanks! I'm gonna stay with the Boggers. If I find a good deal on some 48 - 50" tractors I'd buy em to run occasionally.
Quote from: Bowtie972 on February 02, 2012, 07:22:09 PM
HQuote from: OHEARN.2012 on February 02, 2012, 06:26:56 PM
yea hopefully i got some 10" lift springs and im saving up for a pair i just want some knowledge on how they work etc before i get them
Cool. Yea, I spent many nights searching online, and learning as much as I could. Lots of info out there. Rocks are cheap enough to get, but the little parts that go with em add up fast.
Quote from: BIG DOG on February 03, 2012, 01:15:44 AM
Quote from: Gearz on February 04, 2012, 09:29:39 PM
Quote from: Bowtie972 on February 03, 2012, 02:34:30 AM
LMAO. ==kk
Was waiting for that to start OC ==sa paperbagg
applaudd ==wgm a=f ++peace
A few pics on 44's. Gonna wrap it up this coming week. Just gotta finish driveshaft loops and its ready to drive out. I hope. Lol
Pics arent the best, from my Cell phone.
sweet!
Nice rig!
Looks awsome in person!
Hey that rear driveshaft looks familiar.. loll
Quote from: OHEARN.2012 on February 19, 2012, 02:46:47 AM
It worked out great! thanks!
Quote from: Bowtie972 on February 19, 2012, 02:52:21 AM
no problem man glad to see it worked for ya
Looks Good man! ==wgm
Wow, nice work. I'd like to see some up close fab work. Getting ready for mine too!
Great job! looks Rock Solid!! ++peace Do I see a new trailer in the works there on the floor?
Quote from: CBakes on February 19, 2012, 04:20:35 PM
Cool. Hopefully be pulling it out this week, ill get a whole new set of pics outside.
Quote from: Gearz on February 19, 2012, 04:28:35 PM
Thanks Tim, Yea your brother is building one here. lol
Its movin on its own power now!! Some new pics!!
More pics
A few more
Looks Good !! applaudd applaudd
woho ==djdj ==roxx Tim your one hell of a great gear head with wrenches and fab work. Hats off to you Great Job!! chevvv
Awesome
Thanks! I appreciate the complements! ==wgm
thts sweet u did great work!
Got some plans for some body work and new sheet metal, and maybe a different color??? Trying to decide.
Cool truck man ..
Very nice job! I'm taking notes...
looking badazz!
nice truck!
looks good like to have those axles
Quote from: Gearz on February 21, 2012, 05:02:13 PM
lookin great!
ill meet you at the mounds.it looks good
who did you get your pinion breaks from?
Quote from: middleroadBOB on February 23, 2012, 12:32:38 AM
I got my brake from DIY4X. Came w/ brackets, rotor and bolts. You buy your own reg Chevy truck caliper and pads. I did have to shim my bracket out 1/8" so the caliper would fit right om the rotor, Other than that it works good.
Very nice.
Looks like room for bigger tires too. :-)
Quote from: TRENT on February 23, 2012, 02:54:04 AM
I see ya made another heavy duty driveshaft loop, haha applaudd
Oh yea. This ones quite a bit thicker than the last one. Hopefully I never need it. Lol
Quote from: four_by_ken on February 23, 2012, 03:16:30 AM
Very nice.
I wouldn't mind picking up a set of tractors to use once in a while. I won't sell my 44's though, I'll run those most of the time.
lets go find some mud ???
A few more pics
that for axle wrap?
I keep reading about this "axle wrap" but I'm confused as to what that means? I'm looking to go 2.5s in the near future and all the pointers that I can get will help.
Quote from: FilthyMoney on February 23, 2012, 03:59:56 PM
A few more pics
that for axle wrap?
i kinda know what it means but when you have somewhat of a high horse motor and ur sitting there and you lay into the throttle youll get axle wrap which means the axle housing itselfs is twisting before the tires actually turn and if u have big blocks etc the amount of axle wrap is multiplied
Can you avoid this by strengthing the housing or adding some sort of link bars? Or is this just a fact of rocks in general? Are there any fixes?
Axle wrap primarily happenes with leif spring applications when under load the axle twists breaking ubolts driveshafts and in most cases cracking of the t case, ways to eliminate axle wrap are ladder bars or a simple link likw what you see with this build, 4 link is by far the best way to eliminate axle wrap, its also the best way to maintain your pinion angle through out your suspensions full movement
Quote from: erikmud on February 23, 2012, 04:52:23 PM
Thats what i was thinking. Thanks guys, sorry for jacking your thread! Great build
looks great!!!
is this going to be at the mounds march 11th?
Unfortunately , no. Mechanically it's done, but I just started on the body work. It's gettin some much needed attention and a new color. No more black. I think. Lol. We'll see. ++peace
Quote from: Bowtie972 on March 02, 2012, 03:31:25 AM
NOOOOO! Keep It black!! I think it would look good all satin black.
PAINT IT BLUE AND WHITE ITS THE WAY TO GO! LMAO
Quote from: rob69 on March 03, 2012, 03:19:31 AM
overdone
Quote from: four_by_ken on March 03, 2012, 03:28:37 AM
overdone
not on mud trucks :)
Color is a hard choice for me. I like black. Every vehicle I own is black. Lol. I have several choices Rollin around in my head. I'd like it to standout.
dont go yellow nothing but bad things happen to yellow boggers! lol
Quote from: Bowtie972 on March 03, 2012, 05:17:07 AM
++peace Hint stay away from red ,white an blue there's some thing in the works there. ;D
Lime green!
Quote from: betterbeaters on March 03, 2012, 01:12:57 PM
Words of experience Alex? lol
Quote from: Gearz on March 03, 2012, 01:42:36 PM
Goin patriotic Tim?
As for Lime green, I just dont know. lol I shouldve started a poll for this. What color to paint my bogger. lol
yep both my yellow trucks got scraped after 1 year! lmao and dave woods rolled his blazer frist time out yellow so its just a bad color! lmao
burnt orange with pearle white stripes
plain old white is what im doing mine
I did the same on that anti wrap bar on the front of my s10 worked great for me
Do a candy color
This would look bad ass on your truck !!
(http://img.photobucket.com/albums/v630/rob_69/100_0260.jpg) (http://img.photobucket.com/albums/v630/rob_69/100_0260.jpg)
That is cool lookin
Quote from: Bowtie972 on March 04, 2012, 04:08:17 AM
That is cool lookin
One day i will paint something like that!! I love the look!
Mov"in up with the BIG BOYS!! lol..... please come pull me out sir..
==noob
Quote from: Orangecrush on March 05, 2012, 01:36:53 AM
Its still wearing the same size shoes. lol you might have to pull me out! ++peace
Quote from: Bowtie972 on March 05, 2012, 02:13:56 AM
==noob
Quote from: TRENT on March 06, 2012, 05:44:54 PM
Ill try and pull eather of ya out(if I can even get to ya, haha)
x2! ;D loll
==noobQuote from: Orangecrush on March 05, 2012, 01:36:53 AM
more tow straps! lol I got you guys back too the old beater on 35s pulled hopper on rocks and 50s before not scared of anytruck! hehehe
Thanks Guys! If mines running, ill pull anyone i can! ==wgm
New to the site and just got a new project and it came with a set of 2 1/2s was wondering where you order parts for yours, and if anyone knows where to get rim made? You have a very good looking truck and the paint never needs to be flashy black suits a BFT just fine
thats is one sick truck!
Thanks Guys!
Quote from: 03yamahar1 on March 15, 2012, 11:20:41 AM
Most of my axle parts I got from Wildtime on this site. Checkout Wildtime Fabrication online. I got some parts online from Red Barn Customs, and DIY4X also.
Quote from: HockeyGuy on March 15, 2012, 12:15:41 PM
Thanks! In process of bodywork right now. Should be shootin paint in a week, and its not Black. lol
Truck looks awesome !!! Can't wait to see the paint you pick
Updates....Lots of rotting in the cab and box on this body. Got new cab corners, rockers and bed sides on both sides welded on. Repaired floor on both sides, replaced both doors and front fenders, with used but solid ones. Got lucky and found a nice tailgate at the junkyard for $25. Recut the holes in the hood, a little straighter this time. Pounded the dents out of the roof, i guess i shouldnt stand on it. lol Gotta thank StumpJumper on the site for the body fill work. Bondo scrapers and sandpaper are not my thing! lol Gonna be shooting color real soon! Pics of progress....
more pics
couple more
i hope it anit ORANGE LMFAO
Quote from: BIG DOG on March 26, 2012, 12:31:23 AM
hey now...lol
lookin good Tim!!
looks good hoped the doors worked for yea
Colors gonna be a surprise! lol
Quote from: Trucker on March 26, 2012, 02:00:24 AM
The doors worked great! Very nice shape! Thanks!
Looking good!!! I hate body work, I don't have the patience lol
Quote from: michigan maniac on March 26, 2012, 03:49:20 AM
Me neither! lol
Looks great!!
you did some very nice fab work bad ass
once you go black, you're not allowed back!
Thanks for the comments guys!
Quote from: marshall on March 28, 2012, 12:48:05 PM
lol
sweet truck
love your truck
Looks Sick Man! Your Gonna Love Them Rocks!
Thanks for the comments! Greatly appreciated! The body work is all done! I cant get the guy here to spray it til next saturday. :( So last summer i swapped my trailer axles out with heavier ones, and i need to widen my trailer out and am making drive over fenders too. Im gonna try to wrap that up this week. TGW is creeping up fast! Gotta wrap this stuff up. I was hoping to test n tune at Ellis rd, not sure if ill make that or not??? GotMud?
Here it is, all done!
Few more
==awesome
looks great love the color!
man she looks sweet as hell
Really turned out nice. Love the color. Beautiful, man.
kick ass truck!
Awesome! nice 468 badge!
that bioych is sexy!! looks killer,great job Tim, you should be proud of it!
Quote from: Orangecrush on April 12, 2012, 09:18:27 PM
X2
applaudd applaudd GotMud?
where did you find the 468 badges
chevgal ==tka Great Job!
Thanks everybody! I'm very happy with how it came out. No more rust! Lol I had a toolmaker at work make the 468 badges for me on the CNC. It only took 2 Years to get em to do it. Lol
WHAT!!!!!
THAT TRUCK IS AMAZING!
Nicely done.
Looks sweet! When do I get to go for a ride?
Quote from: Stump Jumper on April 12, 2012, 11:43:31 PM
l
Whenever your ready!
Turned out great!
To nice to bog now ;)
Quote from: homewrecker john on April 14, 2012, 03:24:51 AM
Never too nice. The last bogger I painted got entered in a comp mud bog 24 hrs later. Lol Sat out all last year, I'm Sooo ready to get it dirty!
nice build man! are the wheels recentered? or does someone make a bolt on app that will except standard tire sizes?
Thanks! I welded in new wheel centers in my 15" rims. I wanted to keep the overall width close to what I had w/ D60. I think it's about 7" of back spacing, almost centered in the wheel. I think Ouverson makes an 8 lug hub, but I think they're $500 ea!
Quote from: CBakes on April 12, 2012, 05:18:24 PM
Quote from: Bowtie972 on April 26, 2012, 11:12:45 PM
sweet that works! i wanna switch to rocks but not really a fan of tractor tires.... will be looking into welding in new centers so i can run my boggers.
That's one bad looken truck
==wgm a=f ++peaceIf anyone gets a chance check out the fab work on this truck, Tim is a helluva wrench and comes up with some great ideas,wish mine was this stout, its gonna be impressive to watch cant wait for that!
Thanks for all the great comments! ++peace. TGW is gonna be its maiden voyage! I'm very anxious to see how it does! It's been a loooong wait, The last time it had mud on it was Oct 2010 at Big Al's!
;D Looks KILLER!
looks sick nice build!
sweet truck looking good
Wow Man!! I Like Your Truck Better Then Mine! Came Out Sick!!!!
Thanks everybody! All the comments make all the work worth it! ++peace
Had a great day at TGW! The truck did awesome! Im thrilled with how it performed...No big issues, broke throttle cable, i had a spare.i think my battery is on its way out too. Left my elec fan on for a little while and it killed my battery. All in all had a great day wheeling with my friends. GotMud?
man i love this truck nice build man
Truck was looking good yesterday!! Was nice meeting you also.
Thanks!
Quote from: rob69 on May 06, 2012, 01:35:34 PM
Always cool meeting GotMud? members!
This truck Rips man.. Looks Awesome..
Yea She Looked Like She Was Ripping!
Thanks!
man i didnt even c this truck wtf was i doing
Are those steel or aluminum rims? And where did you get your new centers? If I got to rocks I'm gonna run my 44 inch boggers
I have steel rims. I got my new centers from Wildtime on here.
Looks good ! applaudd
Quote from: Bowtie972 on May 22, 2012, 12:34:23 AM
Cool thanks !!!
==np
My BBC is hungry, time to let her eat!! ==wgm Holley 950 CFM Ultra HP
nice!
let r eat!
Quote from: Bowtie972 on February 23, 2012, 02:50:24 AM
Your rotor is on backwards, I bought and installed the same kit, it came with no instructions so I went on their website and found this pic (http://i1120.photobucket.com/albums/l490/gregor214/tn_rockwellpinionbrake2-500x500.jpg)
I know its kinda late now lol, but if you ever wanted to remove the Spacer you could
No, actually its not. The pic you have up, to me it looks like the chunk is rotated 180, or its a front axle. If you look at my pic, and the way the bracket is in relationship to the rectangle cover and side cover, its actually the same. The problem i had was with how the rotor fit in the caliper, it wasnt centered right. I had to shim the bracket out for that. Spinning the bracket wouldnt change that, it would still be on the same plane. I had talked to Kert, the owner of DIY4x, he said sometimes one doesnt get bent quite right, he told me i could send it back for a new one, i chose to shim it 1/8' instead.
Your braket is fine, its the rotor that is on backwards, see in my pic how you can see the rotor cooling fins, and cant see the tabs that bolt the rotor to the hub, and in your pic you can see the tabs, if you were to flip your rotor the other way and remove the 1/8 inch Spacers for the bracket, everything will fit perfect, I should've been more specific in my first post, I made the same mistake with my kit when I first installed it, the caliper didn't fit right, then I.flipped the rotor, and now its perfect, I took mine apart 3 times before I figured it out,
I tried it that way too, it was offset too far the other way. It works anyway. Lol.
As long as it works that's all that matters!!!
Picked up some different shoes Saturday.. Thanks 2Trackr.. 14.9-26's, real nice shape on recentered tractor wheels, about 50" tall. Gotta do some fender trimming, and pull them back off and wire wheel and repaint this winter..But, I cant wait to try em out!
Im in love with your truck lol very nice
That looks bad ass!!!
Sweet
very nice
looks great tim
Rock on! Love the new shoes
Thanks guys, I still have the boggers too, not letting them go
Wow i love how this truck turned out!
Nice!! ==roxx ==roxs ==drooling
Quote from: Bowtie972 on February 21, 2012, 04:36:08 PM
More pics
did you clock your t-case? any problems with running the 241 so far? im going to try and run a 208 seeings how funds for a profab are out of the question.
Yea i didnt have that kinda money either. Might go to a TH400/NP205 someday, but what ive got works for me so far without any issues. Ill snap ya some better pics tomorrow and post em up.
sweet truck
It looks alot better with the tractor tires i think
Underside pics
Some more
Few more
Looks good
applaudd you did a good job building that beast! like how ya made everything simple and strong.
Well i tried out the tractor tires out this past weekend, and im very happy with how they worked out....But..... the horsepower bug is biting the p00 out of me, so some changes are comimg soon..... ;)
blower motor???
Looks bad to the bone man!
Awesome looking truck! This is exactually the same way I wanna build mine. I love how you did your suspension and brackets on here. Did you make a build sheet as you were doing this? I like the height and stoutness of it compared to others I've seen. I'd like mine to go from this to that. Once again...Awesome looking truck! ;D
Thank you! Thats a nice looking truck you have too. I decided to change it back to black before TGW. Had a few issues there, broken trans case being the worst. But, im gonna throw another trans in to finish the year out and time for some upgrades this winter.... ;D Anything you wanna know just ask, but its basically 8" springs on 6" perches, and a shackle flip with longer shackles in back and a drop mount in front.
Truck is definately sweet! nice job tim
==wgm a=f Yeah this truck runs as good as it looks! ++peace
Quote from: Orangecrush on September 01, 2013, 12:31:57 PM
Yes it did!
How did you make the shims for the rear leafs? And are you running a tcase drop? http://wegotmud.com/forum/index.php?action=dlattach;topic=71783.0;attach=62934;image (http://wegotmud.com/forum/index.php?action=dlattach;topic=71783.0;attach=62934;image)
It wasn't blue very long, why the change?
anything new
Yeah I'm curious to see this new build
Quote from: Bowtie972 on August 31, 2012, 01:38:26 PM
I am building same truck set mine up the same way per Kert as well
looks good
Sorry guys I didn't realize anyone posted on this recently. Lots of things have changed. The truck is more or less scrapped. I wadded the frame badly at Perkins bog. I decided it was time to step up my game. It's already in the works, ill prob start a new thread. Whole new truck coming out. Literally the cab and the axles are the only parts I'm reusing. New motor, trans, Tcase, suspension, lots of goodies in this one. Here's a sneak peak at what's coming.
No idea why these pics turn sideways. Lol
Build is looking good! I still need to stop over and check out the progress, I live just around the damn corner. ++peace
That's a game changer for sure !! Looking bad ass
Thanks! I'm gonna be doin some reassembly this week. Then ill get some updated pics
you buy that chassis tim?
Quote from: marshall on April 12, 2014, 01:23:43 PM
Greg Johnson at "1 of a Kind Fab" in Gregory built it for me
this is a sweet build!! cant wait to see this ripping up the mud! , nice build Tim!!! ==kp ++peace a=f
Sweet
Makin good progress. Motor came home today, goin in tomorrow morning. Truck is also gettin paints this weekend. Hoping to do some testing next weekend.
Few more
Dang sideways pics. lol couple more pics.
looking good man applaudd applaudd I see my old dually in the background too ;D
Thank you. Yup, the boys plugging away at it. Should be on the road soon
This things gonna rip !! Sweet build
Thanks! Motors in, hopefully have it started Sunday. Father in law started painting today. It's coming together.
looks great!!!!!!!!!!!!!
Thanks! Now if I can only get spark! ==hmmm
Bad ass!
Thanks! Here's some current pics. Almost done.
Stepside! And its blue again! Nice!
Yes sir! It's staying blue too! Lol
Wow that is nice !!!
Thanks!
Looks awesome
Looking good man!! Is that drive shaft I sold ya still holding up?
Thanks! It was still on the truck til last fall with no problems. It did the job for sure. I had to have 2 shafts with slip yokes built in for the SCS, so I opted to get 2 new ones made. I went with a little heavier wall thickness too, I've got a trans brake to play with now. Lol.
Hell yea should be a ripper. I still need to take ya up on that ride offer lol
Quote from: OHEARN.2012 on May 31, 2014, 02:53:47 PM
Anytime. See me at a bog come say hello
Bad ass a lil jealous
After its first bog at Perkins, ive been workin on some of the bugs.. did some suspension tuning, switched over to a complete serpentine belt system, broke a throttle cable at perkins too... went to bobs bog, broke another brand new throttle cable, but rigged it up enough to continue, then broke all 4 axle shafts in the truck. I was heading across the swamp banged 2nd gear and then I was hittin the rev limiter and no go... Orangecrush towed me out of the pit.. end of the day for me....
So, I don't think I can swing upgraded shafts right now, so I might be putting stockers back in for TGW...
Other than that, im real happy with the truck, the suspension feels great and I love the power it has.. just gotta get it to the ground w/o breaking shafts
Damn that sucks, it sounded good comming threw the swamp till it broke, looks like your making some good power it looked like the front tires were lifting off the ground when you first took off from next to the tent
I love the big cubes.
I love that whole truck lol
Thanks. Lol
one baddass bowtie!
Bowtie972 Do you mind if I ask what that chassis ran you. Was thinking maybe having greg over 1 of a kinf fab make me one up or see if he could do a frame swap for me. You're welcome to PM me if you dont want to post on here. Trying to figure out whats going to give me what i want and whats most cost eeffective. Thanks
P.S. THAT IS ONE BAD ASS TRUCK. I CAN ONLY DREAM THAT BIG FOR NOW. been planting dollar bills all over the back yard but no growth yet. maybe I planted wrong time of the year. lol
Had a great time at TGW with the Mean Streak.. Had a few minor issues on Friday, water pump started leaking, and kept throwing my Serpentine belt too. Got those issues taken care of, and got out for a few runs later Saturday. Felt great to get some real seat time in it!
Axle shafts all held up great too..
watched you run late saturday by the bleachers and watched you do a small wheelie
Quote from: 355REDNECK on August 24, 2014, 11:58:35 PM
Awesome!
Lots of derby guys have been using aftermarket gas pedals. They are about $200, but are super smooth and made tough. Might be worth checking into if stock cables are giving you problems.
I have looked at those. I bought a Lokar braided stainless steel cable before TGW. It seemed to work great. If it does give me problems, aftermarket pedal is next.
Lovin the 4 link and 18" travel shocks , was planning on trying the freestyle at The Country Compound, but a bent shock mount ended my day early.
that truck rips looks runs and sounds ==awesome
Quote from: BigFrank on September 16, 2014, 10:24:48 AM
Thanks Keven
