Projects & Parts => Garage/Tech => Topic started by: bigmud44 on January 03, 2012, 04:55:30 PM
Title: 95 yukon t case
Post by: bigmud44 on January 03, 2012, 04:55:30 PM
want to sas my yukon with chevy axles is there a  pass side tcase that will bolt up up to 4l60  ???
Title: Re: 95 yukon t case
Post by: J.C. on January 03, 2012, 05:03:55 PM
If it will bolt to a 700R4, it will bolt to that. 27 spline output. You will want a passenger side drop 241 from a 90-91 blazer/burb so your speedo works. ++peace
Post by: bigmud44 on January 03, 2012, 05:07:14 PM
Quote from: J.C. on January 03, 2012, 05:03:55 PM
If it will bolt to a 700R4, it will bolt to that. 27 spline output. You will want a drivers side drop NP241. ++peace
so you just reclock it ?
Post by: J.C. on January 03, 2012, 05:09:24 PM
i misread, and misspoke. fixed it ;D
Post by: ToughBowtieTruck on January 03, 2012, 10:47:23 PM
Up until 1997, the passenger drop case can be bolted to any 4L60-E. when they changed the mounting for the transfer case (added another bolt to the flange).
Bingo.
Post by: solid 12 on January 04, 2012, 02:27:24 AM
Quote from: ToughBowtieTruck on January 03, 2012, 10:47:23 PM
Bingo.
I have a 98 silverado that i had a pass side drop 241 bolted up to a 4l60e..so inorder to sas your tahoe u will need a pass side drop 241
***Moved your reply outside of the quote for ya.  8) --ToughBowtie
Post by: bigmud44 on January 04, 2012, 05:39:42 AM
thanks for help gentelman applaudd GotMud?
