Projects & Parts => Garage/Tech => Topic started by: jwang203 on January 14, 2012, 04:48:07 AM
Title: can someone help me decode this 350?
Post by: jwang203 on January 14, 2012, 04:48:07 AM
Here is a picture of the stamp above the water pump. I cannot find out what this came out of other than its a 350. Any help? Thanks.
Title: Re: can someone help me decode this 350?
Post by: Jjay78 on January 14, 2012, 04:50:02 AM
the rest of the casting numbers can be more of a help than those ones....their easily faked or changed...
Post by: Jjay78 on January 14, 2012, 04:50:43 AM
the ones on the bell housing flange and the ones on the heads are more important
Post by: xjs3667 on January 14, 2012, 07:07:09 AM
Im not coming up with anything either I think its a fake stamp,  get one off bell housing flange and I can run that one   ;D
Post by: jaredw on January 14, 2012, 10:08:23 AM
ok thanks I will try and get one tomorrow
Post by: J.C. on January 14, 2012, 01:32:15 PM
Its a 1988 350 E.F.I V8, R/V models truck engine, RPO L05.
http://www.camaros.net/forums/showthread.php?t=23337 (http://www.camaros.net/forums/showthread.php?t=23337)
Post by: jaredw on January 21, 2012, 07:39:43 AM
Thanks. I wasn't able to get another picture of it.
Post by: xjs3667 on January 21, 2012, 03:45:57 PM
V0627PHD
V- Flint Engine
06- June
27- day 27th
PHD- 1988 truck 350  195 hp TBI
Im pretty sure second stamp is fake as when I run it i keep coming up with 68-69 camaro 396, but I will keep checking, but the only way to know for sure is to get the number trans flange  ;D
Post by: xjs3667 on January 21, 2012, 04:25:20 PM
ok and after some real long hard research for ya this is what I found on the partial vin
CJF189958
C-Chevrolet
JF- HD truck 3/4 or bigger or RV
1-Chevy
8-1988
9- Detroit Assembly plant or Oshawa Assembly plant
Post by: jaredw on January 24, 2012, 10:42:38 PM
Thanks guys. This motor was purchased as a rebuild from someone. After installing it and having tons of issues it spun a crank bearing after about 300 miles. Its coming back out.
Post by: Jjay78 on January 24, 2012, 10:43:46 PM
perfect time to do some upgrades to the motor then man!!!!
Post by: jaredw on January 24, 2012, 10:46:10 PM
its in a friends DD truck, stock tbi setup 1994 k2500
Post by: Cannaert on January 26, 2012, 07:49:48 PM
I would also get the one that is cast in the block by the bell housing.
I know the one on the front is the plant code but the other will help you out as well.
Post by: mudbrat71 on January 27, 2012, 06:26:32 PM
got a 94 350 tbi $300 run good when i pulled in dec
