Projects & Parts => Garage/Tech => Topic started by: Captn. J on February 10, 2012, 02:17:02 PM
Title: winch cables
Post by: Captn. J on February 10, 2012, 02:17:02 PM
i was gonna cut up some jumper cables which is 8 gauges    will they be fine?
Title: Re: winch cables
Post by: xjs3667 on February 10, 2012, 04:58:09 PM
depends on what size the winch is, If its an old pair of jumpers then just cut em and try it out with a load on the winch and see if they get hot,  I know most jumper cables are made of a bunch of the small this copper wire where as some thing like the winch cable is a bunch of thick copper wire.
You could always go to a junk yard or find some old battery cables, and use them, that would be the best way to go imo
Post by: ToughBowtieTruck on February 10, 2012, 05:11:45 PM
Mine is 4 or 6 gauge. Biggest booster cable set Walmart has. Put terminal ends on one side and quick-connects on the other to the winch. Works awesome with my 10,000lb winch. The storage bag is now used for my tow strap as well.
Post by: Captn. J on February 11, 2012, 11:47:44 PM
ok after my comalong pissed me off after struggling to get a wrecked truck for parts  i decided i m gonna get wires for my winch....  so i m gonna get some cables from walmart n cut em up    but where do i get quick disconnects at? and butt ends with hole for batteries or at the winch?
Post by: ToughBowtieTruck on February 12, 2012, 01:54:02 AM
Quote from: Captn. J on February 11, 2012, 11:47:44 PM
I got my quick connects at Napa. 35 bucks or so. Supposed to be able to solder the ends on but I just put them in a vise and "crimped" them together. They're blue in color.
As far as the battery ends you can leave the booster clamps on it if you will just use a remote battery, or just get those clamp-on terminal end replacements.
I can get a pic of my setup tomorrow and show ya . . .
Post by: Captn. J on February 12, 2012, 02:42:35 AM
Quote from: ToughBowtieTruck on February 12, 2012, 01:54:02 AM
that ll be cool   i do plan keep one side as booster clamp , and other set where i can set it front of a truck and not using a booster clamps.   pic will help thanks   and u re saying 35 bucks for  both end   female n male? kinda?
Post by: ToughBowtieTruck on February 12, 2012, 03:17:53 AM
35 or so bucks for 2 connectors, allows one connection to be made. I originally had my booster cable set on a truck to run the winch (I have it on a 2" receiver mount) but since sold it and just tote a battery around now when I use the winch on the trailer. I welded a 2" receiver on the trailer so setting the winch up is as fast as putting a trailer hitch in a receiver.
++peace
Post by: ToughBowtieTruck on February 12, 2012, 03:25:40 AM
This is the cable set I bought: http://www.walmart.com/ip/Everstart-4-Gauge-Booster-Cables-20/16817348 (http://www.walmart.com/ip/Everstart-4-Gauge-Booster-Cables-20/16817348)
Post by: Captn. J on February 12, 2012, 01:21:35 PM
Quote from: ToughBowtieTruck on February 12, 2012, 03:17:53 AM
++peace
thats my plan i m gonna mount or weld a 2 in receiver on my trailer so i can use my winch/cradle on the trailer
Post by: ToughBowtieTruck on February 13, 2012, 02:54:19 AM
Here's my pics. Love my Harbor Freight winch. Can't beat a 5 ton winch with receiver mount for $350. ;D
(http://i113.photobucket.com/albums/n206/toughbowtietruck/Photo-0364.jpg) (http://i113.photobucket.com/albums/n206/toughbowtietruck/Photo-0364.jpg)
(http://i113.photobucket.com/albums/n206/toughbowtietruck/Photo-0365.jpg) (http://i113.photobucket.com/albums/n206/toughbowtietruck/Photo-0365.jpg)
(http://i113.photobucket.com/albums/n206/toughbowtietruck/Photo-0366-1.jpg) (http://i113.photobucket.com/albums/n206/toughbowtietruck/Photo-0366-1.jpg)
Post by: Captn. J on February 13, 2012, 03:43:36 AM
thats pretty much what i have too ... the control box aint mounted on my cradle but how did u ?
Post by: ToughBowtieTruck on February 14, 2012, 03:45:22 AM
Quote from: Captn. J on February 13, 2012, 03:43:36 AM
My winch came with the mount. Two bolts to bolt the mount to the side of the winch, and a big zip tie to hold it on the other end. That's all it is.
