Projects & Parts => Garage/Tech => Topic started by: bud on March 01, 2012, 04:37:20 AM
Title: cam shaft sesnor code still on???? 05 dodge ram 4.7
Post by: bud on March 01, 2012, 04:37:20 AM
ok i have a 05 dodge ram 4.7 4x4 77,000 miles last week my CEL came on po344 cam shaft sensor no big deal right? wrong changed the part out cleared the code then 2 days later started the truck to let it warm up went out there to leave and the dam CEL is back on same code i have cleared the code 4 times now it will stay off for a while it only seems to come back on at start up or when i let it warm up and stays on till i clear it again so i am stuck any ideals????
Title: Re: cam shaft sesnor code still on???? 05 dodge ram 4.7
Post by: bud on March 01, 2012, 07:06:14 PM
nobody???
Post by: High Strung on March 01, 2012, 11:10:54 PM
I had the same problem in my 04. might kept tell me it was cam then it went to crank. then after i replaced both them it started stalling.. this all happened. in a years time.. finally after it stalled and didn't want to start up. i said f++k this. sold the truck to a dealership. that's all i can tell u. 1 mechanical said the only thing he can say is tear the motor done and start testing sensers. and check cam and crank.
Post by: bud on March 02, 2012, 12:46:02 PM
Quote from: High Strung on March 01, 2012, 11:10:54 PM
yep that aint going to happen lol
Post by: Eroq on March 04, 2012, 06:42:07 PM
Does it run rough when the light kicks on?
Post by: 01vortecpwr on March 04, 2012, 08:53:12 PM
those 4.7 are  a scary motor
Post by: bud on March 04, 2012, 08:53:51 PM
Quote from: Eroq on March 04, 2012, 06:42:07 PM
not like its a bad cam sensor might run a little rough but not bad at all
Post by: jbeery78 on March 05, 2012, 01:59:39 AM
 4.7s are tricky for sure.... ill bet a failing crank sensor is causing the cam code... i had a 4.7 with a smilar prob kick my butt for a whole day. Cam and crank share a 5 volt and a ground and the pcm gets "confused" haha.
Keep us posted!  ++peace
Post by: bud on March 05, 2012, 03:45:07 AM
Quote from: jbeery78 on March 05, 2012, 01:59:39 AM
will do i have been hearing alot about changing the crank sensor
