I'm debating getting a 3'' body lift for my ramcharger. I know a lot of guys dont like running them. My floor boards are all solid so breaking through wont be an issue. I was just wondering what you guys thougt. Oh, btw ill be building my own steel bumpers after i put the lift in to compensate for the gap. Will I have to extend any linkage? Oh, and where is the cheapest place to buy one w/o bumper brackets. My truck is HUGE now im just looking for that little bit of tire clearance to stop the rub and because bigger is always better! Thanks -Corey
Ok so im 5'8 and this is me standing next to my truck. A 3'' body lift will put my truck right about where I want it to be. If you look at the front fender in front of the tire, thats where im scrubbing at
nay
Nay! Shows too much frame...
Don't do it. You'll be glad you didn't. 3" body lift makes everything related to the body 3" higher than everything related to the frame. Fan shroud won't work anymore, you'll have more fender gap allowing stuff to get into the engine bay, linkages will have to be modified, and so on. The engine will be 3" lower in the engine bay, making certain repair jobs harder.
Bigger tire is not always better. Think about it this way: My 32" tires can do the same as a 36" tire. Why? Although a 36" tire is 4" bigger in diameter, you only have 2" of that tire making contact with the ground, so you only get 2" extra total clearance, because your axles will always be the lowest part of the truck that won't be moved through lift kits. But a 36" tire requires a 4-6" lift, usually. That's a LOT of extra lift for that tiny bit of more ground clearance.
Just keep that in mind. ++peace
somtimes just have to .. have one on mine for clearance issuse. have not had an issue, mine was just somthin we made up at the shop nothin fancy and i drive mine on road also..
only thing i did was reinforce the bottom of the core support
get with flatblack he can get what u need reasonable
also body lifts can egg shape your body mounts after a wile. Body lifts are very hard on your mounts.
I run a 3" body lift in my bogger. No problems after 4 1/2 years, also take my truck to Rocks&Valleys and twist the s&*t out of it.
Body lifts are not that bad and you don't always have to lengthen cables or linkeges depending on the application, and some times body lifts make it easier to work on things gives you more room for your hands and certain tools, as for the radiator shroud, remount it and it will work fine, if it makes to much gap between the body and frame u can make or buy gap gaurds, depending on how much lift it already has some times a body lift is your only choice to meke clearance for your tires , if u already have suspension lift adding more lift to the suspension could cause problems with driveshaft angles makeing the body lift your only option
Nay harder on mounts but it does make working on some things easier.
I say just cut a lil more. If you were doing it to get bigger tirfes under it then yes, but if what yer runnin now works for yer tires then why make the center of gravity higher?
Quote from: ToughBowtieTruck on March 01, 2012, 05:57:26 PM
I'm running 39.5''s now. My front fenders rub my tires and they're chewing them up. I don't like the idea of any more mud getting in my bay i've had a lot of issues with that already. As far as my shroud that hasnt been hooked up in years. I also don't like the idea of extending my linkage. This truck WILL be driven on the road. Not far just the hour north to R & V and maybe my 5 min drive to work ever now and again when I feel froggy.
Quote from: erikmud on March 01, 2012, 07:42:44 PM
I saw gap guards for sale online, if i go this route i plan on making my own like you said. I guess i could do the same thing to keep mud out of my bay. Im completely maxed out on suspension lift. my driveshafts are already hitting the yokes. I dont really wanna set up a divorced t-case. 2'' to 3'' should be enough to keep my tires. I could trim them up i guess but i would rather keep my fenders intact and throw the body lift in. Body mounts and linkage is my only concern right now. I need to find someone whos put a body lift in a 1st gen dodge truck. FLAT BLACK WHERE ARE YOU!!!!
Quote from: Blazin40s on March 01, 2012, 07:56:31 PM
OH YUPP! I completely forgot about my center of gravity. I'm WAY high centerend now. Uncomfortably high centered on hills. I plan on spending every other weekend this summer at R & V and Silver lake. Thats a complete game changer I dont roller big country over
I like to keep it as low as possable with biggest tires possable. That way the rig is much more nimble on the trails.
How much lift u got with the 39.5? Cause my buddy has 6in lift on his r.c. and trimmed fenders and he has no issues of body contact with the tires.
I didnt put the springs in so id have to measure mine and my buddy from work has a stock height. It's pretty big but its not stupid huge. The only place i scrub is the front on the fenders. I could prolly get away with trimming 2'' or 3'' and be fine. I put a 2.5'' spacer in my '97 and ran 35''s with no issues as long as i wasnt maxed out turning
X2
The important stuff is Bigger Tarhs.....body lift away....sheet metal is over rated anyway..go ahead and pick out a michigan vehicle/Bogger that doesnt need rust repairs/cab mounts anyway .....body lifts are great for the guy who needs to tune his stuff or wants more room to powerwash his schtuff ;D
he's talking mopar not chevy. you do not need to cut fan shroud. you move rad down drill new holes.as far as body mounts on a dodge is the same size as the body lift blocks. you need to get the body bolts tight, when you have body mounts problems is cause you did not get them tight enough. body lift makes easier to wash the mud off the under side of the body & frame
Yes do it. Toss the fan and fan shroud in the ditch and get an electric fan. Makes it so much easier to work on and clean up.. Might have to extend the steering shaft a bit, just slide a piece of pipe over it after its cut and tack it good.. Linkage as necessary, maybe reroute or add to wiring.. NO BIG DEAL. ;D
its yours do as ya wish i,ve been wheeling all my dd for 15 yrs and have body lifts in all of them.
I like body lifts personally, they make it way easier to work on and wash the underneath. I put 4-1/2" x 4-1/2" plates on top to make it stronger than factory and to keep more support on the body mounts.
Id rather see body lift than guys that cut half the fenders out to fit tires
Most body lifts come with everything you need! I put a 3" on my dodge and it came with everything..
Quote from: 71 Highboy on March 03, 2012, 12:11:33 AM
i love cutting fenders
I say do whatever you think you need to do to make 'em fit ,don't be scared ,put the body lift in & hack the fenders ,done it many times.
Higher = bad. Keep it as low as poss and fit as big of tire as poss
Quote from: Blazin40s on March 03, 2012, 02:13:53 AM
low and fast!!!!! tall trucks roll easyer.
But that's a fun ride having a top heavy truck, and wheeling hard trying to keep it right side up, its a good time
Yeah, the only thing im worried about is center of gravity. I'm gonna go ahead and put one in i think. I've got a few things I need t do first then im gonna order the BL from summit
Quote from: Bryank on March 02, 2012, 10:05:38 PM
Where did you get your from? How much was it?
Get a hold of flatblack! he can hook you up..
Quote from: BigCountryDRC on March 03, 2012, 08:37:34 PM
I got my 3" body lift years ago from 4 wheel parts warehouse for $80. i dont know how much they are now?
**Fixed quote -ToughBowtie
Hey, I wanna thank everyone for your help and opinions.
Quote from: BigCountryDRC on March 03, 2012, 08:35:51 PM
Center of gravity stays lower on a body lift than on a suspension lift.
Seriously? You dont really believe this, do you?
Quote from: Blazin40s on March 01, 2012, 09:08:22 PM
I know someone else that builds their rigs this way. ++peace
Quote from: four_by_ken on March 08, 2012, 02:19:56 AM
My truck ALWAYS hangs up on the 14 bolt axle. No matter if I had 32s or 37s on it. Whatever bigger tire diameter, the axle clearance is only increased by half.
Quote from: ToughBowtieTruck on March 08, 2012, 04:10:45 AM
True on the 14 bolt. But you take your 32s and I'll take some 36s and we'll see who goes where.
u can shave yr 14 bolt by alot on the bottom seen it on website
Quote from: four_by_ken on March 08, 2012, 02:21:04 AM
That would be like EVERYBODY out west in the desert. They try to keep the COG as low as possible to keep from turnin over on steep trails.
Quote from: old school truck dude on March 08, 2012, 01:34:55 PM
I meant me. :-)
body lifts put way to much stress on the body it self. id keep it low and do some trimming if need be. you can trim and make it look super clean and never know it was trimmed.
ce
Nice picture of toys.
I didnt spend much time lookin for a good pic loll Heres a little bit better one ;D
Much better. :-)
Well i only need about and inch of clearance to keep off that front tire. Ive learned more from flat black about dodges than anyone i know so maybe one clean cut wont hurt anything. Its not like im scrubbing bad its just that one spot
post some pics when your done!
Quote from: betterbeaters on March 11, 2012, 06:05:16 PM
10WD40 ROGER THAT! Looks like im gonna be picking up a '11 Kawasaki Ninja, so my newest plan is to get this RC at least running RIGHT, so I can take my son to a few trips to R & V this summer. Besides the necessary repairs theres prolly not gonna be a lot of building going on for a bit.
HEY! So if my trucks out of time what could that be? I checked the firing order off a print out from online. Then i bought the manual. I can get it set where it runs perfect at idle. As soon as i put it in gear and drive it under load it misses, cuts out and backfires BAD. Adter about 1/4 throttle sometimes it cuts completely out, almost like it stalled. Then if i feather it back itll pick up and run again. My buddy thinks it jumped a tooth but im sorta doubtful about that. I pulled two of the plugs and theyre both pretty nasty so maybe ive actually got it timed right and its just missing from the fouled plugs? How would i know if i was off a tooth?
From TDC on piston #1 the rotor is pointed to what should be plug #1. Facing the distributor its the one not closes to me but one to the left. I've also found a few things online saying that #1 on the distributor is the one closes to me.
I'm gonnna swap plugs this weekend and try and set it again and see where that gets me.
From body lift to engine work!! What's going on here? I'm lost!!
I would start with a tune up then ask flat black to help tuning hes the mopar man!
nay
Well i figured id start the missing issue as lang as i had everyones attention. I can start a new thread if it would make you happier
No just messing with you.. Go with betterbeaters idea and get a hold of flat black! He is the Dodge guy!!
I pulled all the plugs this afternoon they looked pretty nasty. I cleaned them all up then set the timing by ear and its running a little better. This weekend im gonna buy new plugs and wires and see if flat blacks got some time to look at it in his shop
Good luck!!
