Projects & Parts => Garage/Tech => Topic started by: BAD APPLE on March 11, 2012, 02:34:07 AM
Title: 3rd gear club
Post by: BAD APPLE on March 11, 2012, 02:34:07 AM
Have always though it was cool when mud trucks could run 3rd gear and carry 6000 or over rpm and spin 40 inches or bigger tires with lots wheel speed,how many of you have trucks with that capability and what is your set up, I run a 462 BBC to 350/208 with 4:56 gears with 40's up front and 44's in the rear
Title: Re: 3rd gear club
Post by: betterbeaters on March 11, 2012, 03:20:37 AM
I did a long time ago........
Post by: Jjay78 on March 11, 2012, 03:27:23 AM
let ya know when i actually get to put it in the mud with the new drivetrain.......
Post by: homewrecker john on March 11, 2012, 03:32:30 AM
i run third......rocks and cut 44 bogs all the way around...bbc...
Post by: michigan maniac on March 11, 2012, 03:03:32 PM
I was wondering the same thing, and what size and brand stall converter people are running,  I've got 355 th400(2wd) to divorced 205 one tons and 456 gears, and 44 boggers  in low range I've got deccent power but in high it seems weak  I was wondering if my stall converter isn't matched right for my engine
Post by: BAD APPLE on March 11, 2012, 03:17:53 PM
Its gonna be weak in high range its a higher gear ratio and I wouldn't recommend running in high when bogging very bad on the trans
Post by: michigan maniac on March 11, 2012, 04:03:40 PM
Yeah it stays in low when bogging,  I've only bogged this truck twice,  and haven't had much seat time in the truck due to.not having any place to run it, I've just noticed that if I run in 2 hi or even.4 high in my yard or up the road it seems like it has no balls till I'm higher in the rpms,  which makes me think the torque converter isn't matched right for my setup,  I'm gonna get the specs for the cam today and  see what operating range the rpms are
Post by: Bryank on March 11, 2012, 04:09:34 PM
i have a 3000 stall converter and thats how my truck is too with small block or big block it just like full throttle!
Post by: BAD APPLE on March 11, 2012, 04:20:14 PM
I think it just has a lot to do with it being in high range
Post by: betterbeaters on March 11, 2012, 04:30:09 PM
Quote from: erikmud on March 11, 2012, 04:20:14 PM
x2 big tires in hi range with out a ton of axle gear is hard on trans parts
Post by: Blazin40s on March 11, 2012, 04:44:44 PM
Not enuff gear with those 44s.
Post by: Squirell on March 11, 2012, 08:31:34 PM
I have a hard enough time holding first on the  limiter
Post by: Blazin40s on March 11, 2012, 09:58:20 PM
I hold 2nd all day with 4.10s.  I think if I got more gear I could hold 3rd.
Post by: 4-play on March 11, 2012, 10:07:56 PM
I might be able to....lol
Post by: TOMAC on March 11, 2012, 10:52:43 PM
Quote from: 4-play on March 11, 2012, 10:07:56 PM
I call BS lol
Post by: Boggen Joe on March 13, 2012, 01:12:22 AM
I run a 388/350/208 3000 stall with 1 tons 4:88s and I can hit 3rd and hold bout 4500rpms
runs good in high now
with my other motors it was a bog in hi
takes alot of hp n torc to run hi
Post by: hot rod heep on March 13, 2012, 01:53:53 AM
i have a 600 hp 670 lb tq   bbc  should be able to run 3ed   if i can get the drive line to stay together long enuf   to see    with 4 10s   and 40- 44s    496/400/208    3500-3800  edge racing converter  in a s10  on a k 5 frame  with d 60 /14 ff
Post by: mutt truck on March 16, 2012, 12:31:36 PM
I have been able to hit 3rd in mine.
I run a 465 buick big block, had a 670cfm on it now going to an 800, 60 front 70 rear, 3000 sthal, 4.88, 350,205 and 44 tires
Post by: mutt truck on March 16, 2012, 12:33:16 PM
I don't really know what the power or torque is on the motor but it is enough to run good so that is all that matters I guess, till I find out for sure one of these days lol
Post by: 85cHeavyMetalBogger on March 16, 2012, 03:51:53 PM
i can hit and hold 3rd all day long at 30 rpm, thats right 30 rpm. On my mountain bike...lol
