Projects & Parts => Garage/Tech => Topic started by: rayning lead on March 21, 2012, 03:49:16 PM
Title: OH YEA RUST
Post by: rayning lead on March 21, 2012, 03:49:16 PM
my f150 is in some need of some rust repair the rear wheel wells are almost non exsistant and the outsides of the floor are gone. and inner cab corners the truck looks great with the bushwackers on it but my truck never gets muddy and i cant sling gobbs out from my wheels. anyone good at body work? the truck is real solid. i want to learn how to do this myself but i would prally get in over my head lol any help would be great thanks
Title: Re: OH YEA RUST
Post by: rayning lead on March 21, 2012, 11:01:43 PM
anyone know how to weld in patch panels
Post by: frdzila on March 21, 2012, 11:54:51 PM
get it cut to fit with a nice tight but weld and slowly make small stich or tac welds alternating where you put them to keep from adding to much heat once it looks like a solid weld grind it and fill it then block it to shape. just work slow and smart.
Post by: Eroq on March 22, 2012, 12:52:05 AM
how do the doors shut?   if theyre tough, prolly need cab mounts and floors...
Post by: rayning lead on March 22, 2012, 03:35:49 AM
the cab mounts are perfect i wont buy a truck unless i look at the cab mounts. the floors are gone from the rockers about 3" in and the inner cab corners  are gone.I'm not worried about how the floor is fixed no one will see the floor but I want it to be solid but the rear wheel Wells are what I'm worried about. And I don't want to use pounds of bondo if you look at my trucks pics it looks great but its what you can't see that drives me crazy
Post by: Cannaert on March 22, 2012, 04:19:09 AM
Go and get the new patch panels and before you cut then spots out Line them up were they need to be. Then mark them with a Sharpie and and then cut the bad spot right along the line.  Then put the new repair piece in place and stitch weld it in place, by this I mean you need to tack weld it around the new piece about every two to three inches (take your sweet time doing this).  It will take a wile but you will not warp the sheet metal and will not need a lot of body filler.
Also a good place to get the repair panels in ABC (Auto Body Complete) in flint. They have a ton of replacement parts in stock.
If you want shop me a PM and I can show you how to do it.
Post by: Red97 on March 23, 2012, 12:18:19 AM
it is going to be hard to put the inner wheel well on the box without taking the boxsides off
Post by: rayning lead on March 26, 2012, 02:44:04 AM
I had another question how do bushwackers work the ones on my truck like glue on and are screwed on in the inner fender would it easier to buy the bushwackers that you have to cut the fenders to fit them or do the repair panels?
Post by: rayning lead on April 05, 2012, 05:38:53 AM
Bump
Post by: Cannaert on April 06, 2012, 03:15:53 AM
you get my PM.
