Poll
Question:
What do You prefer?
Option 1: Duramax
votes: 12
Option 2: Powerstroke
votes: 4
Option 3: Cummins
votes: 15
was thinking about getting suin small like a jeep. but now i think i want a diesel just because they get good gas milage and because they are good for towing and i need something to tow my bogger when i finsih it. i dont know much about them so gimme the ups and downs of these three motors. i kinda want a cummins but also wouldnt mind a duramax
Cummins baby. There in the big rigs, reliable, straight 6 so they run forever.
They all have there issues.
Cummins for me. do a custom jeep with a 4bt. best of both worlds lol
Quote from: TopFist on April 22, 2012, 05:24:09 AM
That they do, get 05 or newer if its a duramax or cummins 01 or newer 7.3 powerstroke or older 6bt cummins or power stroke just avoid the chevy 6.5s
Quote from: burl on April 22, 2012, 07:14:24 AM
My 6.5 is going strong. Its just like any other vehicle. Hit or miss. Talked to a guy at work that had to replace all kinds of stuff on his 07 Cummins that wasn't even at 150k miles.
Quote from: Chevy Racer on April 22, 2012, 12:43:11 PM
My 6.5 is going strong. Its just like any other vehicle. Hit or miss. Talked to a guy at work that had to replace all kinds of stuff on his 07 Cumins that wasn't even at 150k miles.
x2 Don't knock a brand just because of the rumors.
They each have their evils pick the truck you want.
Buy one, and give it to me for a few months and ill text out the motor for u
cummins.
i found a 2001 Dodge 2500 with a 5.9l cummins in it. it has 215xxx miles body clean as hell overall the whole thing is clean and they want a lil under 10 grand for it. i talked to a friend who is a diesel mechanic and he told me to call and get a ecu report to see if its ever been chipped or reprogrammed so im going to do that monday
i agree.. my 6.5 in my van is stl running good dont get me wrobg i did spend a grand on a remote pmd and a new ip but it wasnt that bad of a fix. and for having almost 400k miles. i think its been a good work vehicle.
On a side note. i liked the pre 98 cummins the non h.o ones seems they slightly went down hill after that. i had a 96 with 600k (used to pull trailer with gokarts from mi to fl. tx. ga) not one problem with the engine in that rig. but the trans let go 2 times
As a diesel Lover in general I can attest that all have their flaws. If you want rock solid engine reliability go with a cummins, drivetrain wise fords have always had an edge. Chevys haven't changed much, still cheaply built but seem to hold together ok for light use. Duramax have had a lot of injector issues, as well as the power strokes. Dodges have been known for weak Trans but is easily fixable.
If it were me I'd buy a dodge cummins and address the Trans ( and lift pump if 24v). Cheap to fix and a drivetrain that will last a million miles.
A simple valve body and converter upgrade will make a dodge tranny very capable, and a good lift pump on a 24v will ensure long life.
Good luck on finding a truck.
get a 6.2 na diesel!!!!! mine pulls over 20 mpg and 15 mpg with my bogger behind it!
it's a matter of preference .. all are good and bad..
what about a 12 valve cummins??
i got a 6.2 but im a cummins fan... If gm would get back to work on the 4.5 non isuzu duramax it would be awesome. 01+ 7.3l powerstrokes were pretty bulit proof minus the torque covertors.
I would buy a 6.0 power stroke before any other one
Quote from: rangerwheelinmike on April 27, 2012, 01:41:12 AM
I like mine.
Im hardcore chevy guy, but if I could afford to buy a new diesel it would be a Dodge.
If your just haulin a bogger once in a while you don really need a diesel...they get better fuel mileage but do the math of maintaing a diesel vs gas and fixing something when it breaks on a diesel vs gas..and diesel is more expensive. Your not going to save any money chances are you'll spend a bit more.
But if your set on getting one...I've had a 99 powerstroke and I had an 89 cummins...the cummins impressed me way more than the ps. Id go with a 12 valve
