Projects & Parts => Garage/Tech => Topic started by: nauss on April 22, 2012, 11:14:38 PM
Title: double cardan joint question
Post by: nauss on April 22, 2012, 11:14:38 PM
anybody ever use a double cardan joint on the rear driveshaft? my driveshaft angle is 30 degree and very sketchy on front u joint so i am considering using one. it is a trail rig only, 91 s10 blazer 350 sbc th350 turbo np208 on 44s any other advice will be appreciated thanx for reading.
Title: Re: double cardan joint question
Post by: BIG DOG on April 22, 2012, 11:39:13 PM
tom woods sells a OFF SET U JOINT    gives like 5 degrees more angle   up to 40 *  60$ each  plus shiping i just got 2 of them   .
  Also you can use wedges to roll the axel up or down   from 2-8 *  to help out
  also lower your tcase mount down more
Post by: BIG DOG on April 22, 2012, 11:41:45 PM
i just drop my tcase over 3"   rolled the front up 4*  and rolled the rear down 6*       the wedges are like 25$ a set    but you may have to redo your leaf spring center pin at this time.
Post by: Mudbuster on April 23, 2012, 12:02:53 AM
yes you can use them in the rear they work fine I used to use one on my jeep because of the driveshaft angle
Post by: michigan maniac on April 23, 2012, 02:36:35 AM
Quote from: Mudbuster on April 23, 2012, 12:02:53 AM
X2
Post by: nauss on April 23, 2012, 01:28:33 PM
Thanx for all the info guys I'm just one step closer now
Post by: BigBlockBlazer on April 24, 2012, 12:31:06 PM
The offset ujoints are not for street use they vibrate bad.  A cv in the rear requires the pinion to be rotated up and pointed at the tcase.
