On The Trail => The Mud Pit ~ Discussion => Topic started by: s10freak on May 11, 2012, 01:11:04 AM
Title: The magic mud
Post by: s10freak on May 11, 2012, 01:11:04 AM
This is what happens when you try to work ground over top of a natural ground-fed spring - an EPIC FAIL for sure. Just an fyi, I am not the one who buried this beast in here like this, and its turning into a real problem to say the least. It's only been in there since 10am yesterday morning and has already sunk at least a foot more like 18". Add to the equation of us jerking the hell out of it for about 4hrs straight, and we gots a serious problem.
Need a damn Steiger and a 50' strap to get this behemoth out of that sink hole, or maybe a major 4wd lol.
We now know conclusively that this Case is stuck. Bottomed out in the rear....obviously. and the front axle beam is damn near ground level (the tractor has sank at least another 6" since these pics were taken this afternoon). Another week or so, there may not be a tractor to recover
Title: Re: The magic mud
Post by: betterbeaters on May 11, 2012, 01:18:20 AM
dozer time!
Post by: Chevy Racer on May 11, 2012, 01:18:39 AM
Dam.  time for one of these.
http://1.bp.blogspot.com/_o4kq5TNL0Z4/TFcUQqkll1I/AAAAAAAAAjk/dDXow9IapPY/s1600/JohnDeere9400pic.jpg (http://1.bp.blogspot.com/_o4kq5TNL0Z4/TFcUQqkll1I/AAAAAAAAAjk/dDXow9IapPY/s1600/JohnDeere9400pic.jpg)
Post by: RIP_K52007 on May 11, 2012, 01:32:37 AM
Wheres Don? ==roll that sucks.
Post by: xjs3667 on May 11, 2012, 02:40:44 AM
get some 6x6 or bigger that about 2-3 feet longer than the rear tire, chain it to the rim so that 1-1 1/2 feet is sticking out past tire on both sides, put her in gear and power out. Its always worked for us,
Post by: PathWayMan on May 11, 2012, 02:49:37 AM
 ==doh  ==kp
Post by: xjs3667 on May 11, 2012, 02:52:24 AM
I knew i could find a vid   loll   its all a different language and he uses some logs and what not  but its the same concept
http://www.youtube.com/watch?v=YnRRGW6z3UQ&feature=player_embedded# (http://www.youtube.com/watch?v=YnRRGW6z3UQ&feature=player_embedded#)!
Post by: 84silverado on May 11, 2012, 02:53:54 AM
Have you tried backing another tractor up to the back of it and holing onto it with the three point and lifting it while pulling? Have you also tried to put thing under the wheels so it can gain traction like rocks or old boards? We had our tractor stuck like that last spring doing 1st cut of hay in a rented field.... Needless to say we never went ba k to that field after we got the tractor out lol
Post by: 4x4xdodgeman on May 11, 2012, 03:12:41 AM
i had 2090 case that thing would find the littlest wet spot and sink like rock. we could not  to pull it out with our 3020 jd. so we get a friends JD 644a loader to pull it out every time. those case are heavy.
Post by: s10freak on May 11, 2012, 07:48:10 AM
Quote from: Chevy Racer on May 11, 2012, 01:18:39 AM
That'd work awesomely in this situation. Need somethin with big tires and good traction.
Post by: s10freak on May 11, 2012, 07:50:09 AM
Quote from: xjs3667 on May 11, 2012, 02:52:24 AM
Yeah we tried that same concept out.....but bc the ground is so soft from the standing water all it did was sink the logs deep into the mud. So now its about 6-12" lower into the mud than what it was when these pics were taken.
Post by: s10freak on May 11, 2012, 08:00:45 AM
Quote from: 84silverado on May 11, 2012, 02:53:54 AM
Yeah we tried chaining to the 3pt arms with the Farmall 400, but all that did was make the 400 ride some serious wheelies. We've tried just about every idea under the son, short of a big boy 4wd tractor that is. We've thrown a half dozen logs into the trenches this tractor made with the back tires, but bc the water line is so high in this area there's basically no bottom to it. every log that we threw in those holes have since disappeared in the mud. We've thrown at least 6 logs measurin about 14" diameter about 2' long into the holes and lost all of them. And yet with all those logs the tractor still sits lower than when we started this morning. Go figure.
Lol yeah that's sounding about like this situation. Its actually our neighbor's back field that he had no use for, so we decided to work it up and plant some alfalfa seed out there to bale for the cows this summer. Not getting off to a great start, thats for sure.
Post by: s10freak on May 11, 2012, 08:03:24 AM
Quote from: 4x4xdodgeman on May 11, 2012, 03:12:41 AM
I'm startin to believe that. It's a great running tractor, has low-range gearing that would snap your neck if ya pop the clutch, but damn it sure isnt the most sure-footed tractor on this property.
Post by: s10freak on May 11, 2012, 08:06:13 AM
Quote from: betterbeaters on May 11, 2012, 01:18:20 AM
dozer time!
No kidding!
Post by: s10freak on May 11, 2012, 08:10:25 AM
Here's a little bit that makes it more interesting. Somehow, not entirely sure how as of yet, but we managed to rupture the rear left tire on the Case. A flat tire adds more difficulty to this already pain in the ass ordeal.
Post by: Uncle Steve on May 11, 2012, 10:55:29 AM
Quote from: PathWayMan on May 11, 2012, 02:49:37 AM
==doh  ==kp
Post by: RaZiN KaNe on May 11, 2012, 11:13:35 AM
LOOKS LIKE A GREAT PLACE TO START A BOGG  applaudd
Post by: xjs3667 on May 11, 2012, 12:09:31 PM
Looks like your guna have to disassemble tractor piece by piece, that will get ya unstuck loll
Post by: BUDGETBOGGER03 on May 11, 2012, 12:41:03 PM
looks like u need mud king to give it a yank with his 66's
Post by: HockeyGuy on May 11, 2012, 01:38:30 PM
Yup, you got yourself one stuck tractor!
Post by: s10freak on May 12, 2012, 03:57:12 AM
Quote from: RaZiN KaNe on May 11, 2012, 11:13:35 AM
Honestly as soon as the f*cker started sinkin into that crap, I thought the exact same thing.
Post by: s10freak on May 12, 2012, 03:58:02 AM
Quote from: HockeyGuy on May 11, 2012, 01:38:30 PM
Major understatement lol
Post by: muddnoob on May 12, 2012, 01:12:21 PM
Quote from: xjs3667 on May 11, 2012, 02:40:44 AM
Post by: RIP_K52007 on May 12, 2012, 01:20:52 PM
==hmmm have you tried hooking 2 tractors or a few trucks to it? Id hook onto it with the suburban if ya had another tractor or truck hooked up also...
Post by: betterbeaters on May 12, 2012, 01:23:03 PM
dod you guys get it out? I think I got a buddy coming to owosso with 64" tractor tires on a blazer mabye he will help ya lol
Post by: RIP_K52007 on May 12, 2012, 01:26:42 PM
heres a idea.... lol. Pile some 8-10ft logs behind it and put a strap around them to hold the pile together. then run your tow strap over the log pile so it pulls up on the stuck one... ==dunno looks like it needs to come up then out.
Post by: Mudduck on May 12, 2012, 08:49:39 PM
Wrap ur recovery strap around the tire at opposite direction of whichever u want ur tire to spin and other end at other vehicle and slowly spin ur tire as ur strap tighten by the turn of ur wheel act as of a winch ur tire will ride on the strap  winding all the way to a hooked vehicle kinda hard to explain but guess that the best i can explain and if anyone has better clear definition of what i m trying to say feel free to clearify
Post by: old school truck dude on May 12, 2012, 08:56:32 PM
Thats an OLD SCHOOL trick and it works great, had to do that several times!!
Post by: BIG DOG on May 13, 2012, 02:39:44 AM
i got a 6000 lb truck with a  10,000 lb winch     50$ i'll give it a shot,   just lookin for the gas $
  hook something to the front of me  for more weight.  to hold me still
Post by: s10freak on May 31, 2012, 10:19:32 PM
FINALLY! ITS OUT! And surprisingly we did it without a big 4wd tractor. It only took getting the old Massey backhoe running to dig out a runoff road, shoveling out the underside of the tractor for 2+hrs, a 6" yank strap and a bogger ('79 F150 400 on 38s) to get it out. That flat rear tire really kicked our a$$es trying to get it out too. But, it's out, that's all that matters. And there's quite the swimmin hole where it was lmao
Post by: 390JOE on May 31, 2012, 10:27:23 PM
==cl congrats
Post by: 84silverado on May 31, 2012, 10:53:44 PM
Atleast you can use the ol girl again around the farm
Post by: betterbeaters on May 31, 2012, 11:09:29 PM
Quote from: 390JOE on May 31, 2012, 10:27:23 PM
==cl congrats
Post by: ballistics-10 on May 31, 2012, 11:12:52 PM
so whens the bog?
Post by: s10freak on June 02, 2012, 12:15:40 AM
Quote from: 84silverado on May 31, 2012, 10:53:44 PM
Maybe after we find a new tire for it that is.
