ok I have a set of toyota axles they are 84-85. I found a 86 rear axle i want to get he has a locker for it. he told me it has bigger axle shafts in it so it wouldnt work on my axles i have now. I want to get the axle and locker he has but i was wanting to put it in my front axle which is the older axle. can anyone tell me if it will work or not. the locker is a power track locker if that helps any. my plan is to weld the rear up for posi and use the locker in the front axle if i can. also he lost the spider gears for his carrier so i was wanting to use the spiders out of my carrier and then weld them up so its posi. any help would be greatful thanks
YodaBill used to be really good with Toyota stuff, I dont think he is a member on here anymore though.
no he isnt but i know him well. i sent him a message on greatlakes and i'll see what he says. thanks
