I'm building a scout 800, the biggest lift they offer is 2 inches. I am looking for a place to get custom springs made. I will be running 39's, a dana 60 front, and 14 bolt ff rear. I'm guessing with the spring over lift I'll need probably 8 to 10 inches of lift. Pre 75' cj5 or cj6 springs are a direct bolt on, so if anyone knows where there's any CJ Springs that would help too
Michigan truck spring in saginaw can order and arch or rearch what ever you need.
Or beatie spring in flint mi
Called michigan truck spring today, they told me to call tuff country to see if they could make what I want....no luck. I couldn't get a answer a beatie spring. Thanks for the help
theres a place in lansing i think its called state spring. i get all my trailer springs made by them
Beatie spring is where I get all my stuff done, they are pretty helpful
Quote from: michigan maniac on September 25, 2012, 01:17:11 AM
Wow....I will call one of the big guys I know at Mich truck and ask him what's up with that, they built my packs and arched them for me couple years ago.
Started as 84 1 ton Ford springs and removed 3 from rear amd added 1 up front with 10" arch on rear and 12 front
Will pm you when I talk to him amd give u a number
livingston spring. fowlerville mi.
beatie spring is always busy matt can get perty much any thing u want or they can make it their good
Quote from: page69 on September 28, 2012, 01:12:47 AM
x2 thats where i go
State spring in Lansing won't make lifted springs. We use ab spring out of grand rapids. They'll make any height spring you want for $200 each I believe. Great quality, but there a bit stiff.
If want some REAL good leaf springs, call Alcan Spring. They know their stuff.
http://www.alcanspring.com/ (http://www.alcanspring.com/)
Something you may want to keep in mind with the old Jeep springs is that they are real narrow and tend to get bent with just 33-35" tires. Going big like you are... I would remake the mounts and go with a 2.5" wide spring.
Also, if you want to stick local to Michigan. Give John R Spring a call.
John R Spring
1782 East Maple Road
Troy, MI 48083
(248) 588-7200
