I picked up a car with a sunpro temperature gauge in it that isn't hooked up. It only has wires on the back, not the actual sensor you thread into the engine. The wires are white, yellow, and brown....my question is, where do they go? Every place I search on the internet (including the sunpro site) only says how to hook up the one that comes with the sensor on the end.....
i just got the white to an accesory and the brown to a ground and it works. i think the other 1 would be for a dimmer. if you want it i still got the directions in the garage i'll see if i can find um
One would have to go to the sending unit, so I guess I'll try the yellow one there and the other two like you said. Thanks.
you sure the sensor wire didnt get broke off clean. i've broke m and had it look like there was never 1 there
