Projects & Parts => Garage/Tech => Topic started by: 73chevytruck on August 29, 2013, 01:25:40 AM
Title: Piston looks melted.
Post by: 73chevytruck on August 29, 2013, 01:25:40 AM
Friend has a .60 396. Bought a few years ago. Finally getting around to do something with it. I pulled the heads off and one of the pistons looks like its been melted. Would it be ok to still run it. Or should it be replaced?.
(http://i1001.photobucket.com/albums/af138/73chevytruck/20130828_174037_zps9ef7d56e.jpg) (http://i1001.photobucket.com/albums/af138/73chevytruck/20130828_174037_zps9ef7d56e.jpg)
Title: Re: Piston looks melted.
Post by: 4x4xdodgeman on August 29, 2013, 02:25:18 AM
need to put it out and look at it. if melt down the side into ring land then its junk.  wrong octane gas or timming
Post by: fordrunner on August 29, 2013, 04:58:52 AM
Its a failer point waiting to happen I'd swap it out while its torn down just my 2 cents
Post by: xjs3667 on August 29, 2013, 07:07:19 AM
X2 swap it out, and yea wrong octane, bad timing or running carb to lean is the cause
Post by: marshall on August 29, 2013, 10:08:58 AM
Quote from: xjs3667 on August 29, 2013, 07:07:19 AM
or too much nitrous
Post by: Thumper on August 29, 2013, 11:55:43 AM
replace it, it's just a bomb waiting to happen
Post by: 73chevytruck on August 29, 2013, 01:16:28 PM
Yea its going to be replaced.
Post by: xjs3667 on August 29, 2013, 03:29:39 PM
Quote from: marshall on August 29, 2013, 10:08:58 AM
or too much nitrous
:-)  forgot about the nitrous loll. It will do it in a hurry
Post by: 73chevytruck on August 29, 2013, 05:47:40 PM
From what I understand somehow the heads had the wrong size valves in them but still let it run.
Post by: xjs3667 on August 29, 2013, 07:41:05 PM
Wrong size valves wouldn't melt a piston...
Post by: MR NASTY on August 29, 2013, 10:41:34 PM
Yes that's true what you have there is detonation cause by wrong timing or to low octane fuel or a combination of both
