Projects & Parts => Garage/Tech => Topic started by: nauss on September 06, 2013, 08:40:19 PM
Title: camshaft suggestions
Post by: nauss on September 06, 2013, 08:40:19 PM
ok guys I am new to the big block world and I am looking for some cam suggestions. I have a stock 454 that is getting a set of the 781 heads (2.06/1.72 valves fresh outta the shop) 2500 stall 5.38 gears on 44's(truck is 3500lbs. guessing). right now I am looking at the comp cam xe274 in which I would just buy the complete kit with springs and eliminate the rotator cup but I figured I would try and get some suggestions from some people that have down this road already. thanks in advance for everybody's time and input. see yall on turkey day hopefully
Title: Re: camshaft suggestions
Post by: Bryank on September 07, 2013, 12:39:31 AM
sounds like you already got it figured! as long as ya get a cam that has a duration which your carb likes it should tune easy and run good. what carb size ya gonna run 750?
Post by: xjs3667 on September 07, 2013, 12:49:28 AM
You need to get can that is best suited for your torque converter....you can always dial in a carb to a new cam but you can't change the stall without changing converters :-)
