Projects & Parts => Garage/Tech => Topic started by: aeckman on September 27, 2013, 02:33:44 AM
Title: Chevy 454 Problem
Post by: aeckman on September 27, 2013, 02:33:44 AM
Just picked up an 88 Chevy 3500 with a 454 in it. Got it no more then 5 miles and it died. Pretty new to big blocks but basically what happened is that the front main seal is slightly leaking and while driving the oil got hot enough, and built up enough pressure to blow the oil cap right off. I let the truck sit for a few hours and now it wont start at all. Almost sounds like the starters grinding on the flywheel when it trys to turn over. What could be wrong?
Title: Re: Chevy 454 Problem
Post by: xjs3667 on September 27, 2013, 02:44:05 AM
Sounds like you were getting a lot of blow by pass the rings and it built pressure up that way and blew the cap off and prolly what blew the front seal, as for the grinding starter idk...
Was it burning any oil? That's another way to tell if rings are bad...
Also does it crank over still?
Post by: Kyle on September 27, 2013, 07:42:16 AM
I had clogged breathers cause crank case pressure like that before
Post by: NuttinButtMudd on September 27, 2013, 10:15:50 AM
donate it to me, I will give u a 350 problem solved!!!! lol no sound like blow by and maybe Pcv might be clogged
Post by: aeckman on September 27, 2013, 10:17:00 AM
Quote from: xjs3667 on September 27, 2013, 02:44:05 AM
It doesnt even crank. It was burning oil pretty bad. How much of a job is new rings?
Post by: Captn. J on September 27, 2013, 10:31:26 AM
Quote from: aeckman on September 27, 2013, 10:17:00 AM
i would go through whole motor not just the ring while u re there ... or find another motor
Post by: marshall on September 27, 2013, 10:50:32 AM
Lemon :(
Sounds like it blew
Post by: betterbeaters on September 27, 2013, 10:59:31 AM
Quote from: marshall on September 27, 2013, 10:50:32 AM
Lemon :(
Sounds like it blew
x2 if it was burning oil bad its hurt
Post by: xjs3667 on September 27, 2013, 02:16:33 PM
Quote from: betterbeaters on September 27, 2013, 10:59:31 AM
Lemon :(
Sounds like it blew
X3 if its not turning over sounds like you seized it.....prolly ran out of oil......and if you do rings, you have to tear it all the way down and at that point you might as well do a full rebuild
Post by: aeckman on September 28, 2013, 03:14:31 PM
Got it to turn over, but its sounding like a rods broken :(
Post by: marshall on September 28, 2013, 04:20:31 PM
Don't try starting it again, it might be rebuildable. Don't put a hole in the side of it.
