Projects & Parts => Garage/Tech => Topic started by: uncletuck on November 08, 2013, 03:49:44 AM
Title: sawpping tbi to carb
Post by: uncletuck on November 08, 2013, 03:49:44 AM
i know this has probably been asked a million times but here goes again........got a GM tbi engine would like to put a carb on it.....will an older stock intake fit on off an older small block.....i cant use the tbi on it cause i dont have a wire harness or computer for it.
Title: Re: sawpping tbi to carb
Post by: Crazymays77 on November 08, 2013, 10:12:23 AM
i might be wrong but if it is a vortec motor then the older style intakes will not work. that is how the 4.3 motors are so I assume its the same for the v8s.
Post by: Captn. J on November 08, 2013, 12:53:56 PM
u can drill the center bolts holes to fit on the tbi block.. seen it work fine ..
Post by: GET-R-DONE on November 08, 2013, 01:50:44 PM
You can buy a intake that will work
Post by: Merc09 on November 08, 2013, 02:24:48 PM
You could also do what i did and bolt on an older set of heads. Then the old style intake will work.
Post by: xjs3667 on November 08, 2013, 02:41:07 PM
With TBI motors all you have to do is whop out the center holes on the intake a little since they bolt down on different angle, and it will work fine
Post by: uncletuck on November 08, 2013, 03:24:17 PM
Well alright doesn't sound at hard as I thought
