Projects & Parts => Garage/Tech => Topic started by: jbeery78 on March 05, 2014, 11:41:38 AM
Title: E85
Post by: jbeery78 on March 05, 2014, 11:41:38 AM
Anyone running E 85 in there boggers? What does a guy need to do to switch? I know ethanol can be corrosive to fuel systems, wondered what I had to do to my carb etc to make the switch. Seems like cheap race gas to me...  ;D
Title: Re: E85
Post by: Boggen Joe on March 05, 2014, 10:35:08 PM
I know you can send your carb out n have it done for like 300-400
Title: Re: E85
Post by: Andy Michalik on March 06, 2014, 02:55:37 AM
I've got a e85 750 on my Chevrolet drag car runs great tip cheap race has now I can run it more
Title: Re: E85
Post by: 4x4xdodgeman on March 06, 2014, 03:18:36 AM
its just like running alcohol, use twice as much as gas. it draws moisture so you need the test tube to see if it has water in it.
Title: Re: E85
Post by: camok10 on March 07, 2014, 10:00:48 PM
To switch your going to need an ethanol compatible fuel system, lines pump seals ect. You need to run the engine ritcher with it either by re jeting or getting an e85 carb. To tune it in your going to want about10:1- 9:1 afr as compaired to the 14.7:1  with gas.
Title: Re: E85
Post by: jbeery78 on March 09, 2014, 08:32:02 PM
Yup I know how ethanol draws moisture, I plan on reworking my fuel system to be compatable with it. Do you guys think a 600 cfm edelbrock is enough carb to run e85 thru or should I step up the cfm? Motor is a 400 ford have a healthy cam heads smoothed up aluminum intake dual plane and headers.
Title: Re: E85
Post by: AtvNut on March 09, 2014, 09:49:28 PM
Use a 750 for that many cubes
Title: Re: E85
Post by: AtvNut on March 09, 2014, 09:50:37 PM
You don't need an alcohol fuel pump I haven't had a problem using a regular Holley blue pump
Title: Re: E85
Post by: AtvNut on March 09, 2014, 09:52:15 PM
If you plan on using pump e85 buy a can of e98 to mix it up to true e85 you will need a tester obtainable from your Briggs and Stratton dealer
Title: Re: E85
Post by: michigan maniac on March 09, 2014, 11:38:09 PM
Looks like 300 to get it converted using your edelbrock http://www.e85carbs.com/EdelbrockE85carbs.htm
Title: Re: E85
Post by: 4x4xdodgeman on March 10, 2014, 03:00:44 AM
I would run at lest 850cfm to 1000cfm carb
Title: Re: E85
Post by: mud slinger on March 10, 2014, 05:36:09 PM
We ran e85 on are bogger we had no problem....u will need a bigger fuel pump aslong with a e85 carb kit....we ran quick fuel carb...but if u call them up they will set u right up
Title: Re: E85
Post by: Andy Michalik on March 11, 2014, 01:15:33 AM
Mine is also a quick fuel 750. Edelbroc will set it up for you I think there is a air bleed you have to solder shut. Bigger from isn't always better if you slow down air speed you can loose power I would stay in that 650 to 750 from range
Title: Re: E85
Post by: michigan maniac on March 11, 2014, 01:30:59 AM
From the link I posted they prefer 500-600 cfm edelbrock carbs for the conversion, but once converted it can never be switched back... So I'm assuming they open it up for more fuel and change the cfm rating regardless of what you start with
Title: Re: E85
Post by: jbeery78 on March 11, 2014, 03:24:37 PM
Ok sounds like I need to get in touch with e85carbs then. From what I find online theyre the go to guys on it.
Title: Re: E85
Post by: Andy Michalik on March 11, 2014, 09:20:19 PM
They guy who started the Edelbroc conversions I spoke with on the phone a year ago he seals up a few Ports not needed then drills a few bigger then puts you're good rubbers. Neoprene in them and rejets
