Projects & Parts => Garage/Tech => Topic started by: Blazin40s on May 02, 2014, 11:59:15 AM
Title: shift cable 97 gmc 2500
Post by: Blazin40s on May 02, 2014, 11:59:15 AM
I have a 97 gmc 2500 2 wd pick up.  Went to put it in park and it wouldn't go.  Will go fine if I lay under truck and manually push the lever forward.  Is tbere an adjustment on this cable?  And where is it?  Heard it may be under the seat and carpet.
Title: Re: shift cable 97 gmc 2500
Post by: michigan maniac on May 02, 2014, 01:02:59 PM
The cable Prolly broke they have a plastic tube inside under a rubber boot that likes to break right by the trans
Post by: Blazin40s on May 02, 2014, 09:24:41 PM
The rubber boot seems to be Intact.  Didn't wanna cut it to look at actual cable. Guess I will.  Is tbere an adjustment anywhere on it?
Post by: michigan maniac on May 02, 2014, 10:05:37 PM
Usually the boot is held on with a factory zip tie, I can't recall off hand where the adjustment is, I believe most are a 2 piece cable and where the 2 meet is where you can adjust It at
Post by: Blazin40s on May 03, 2014, 12:06:11 PM
Guess I gotta pull my seat out n trace down the cable.
