Projects & Parts => Garage/Tech => Topic started by: Boggen Joe on June 09, 2014, 10:35:01 PM
Title: brakes
Post by: Boggen Joe on June 09, 2014, 10:35:01 PM
Ok I'm running 1 tons n brakes suck. I sm not running a booster because only got 6 lbs of vac. And only running fronts.
I need better brakes bad very bad. Any ideas pls
Title: Re: brakes
Post by: 4x4xdodgeman on June 09, 2014, 11:49:45 PM
what do you have for master c?  or what port are you using?  how do you have lines run?    on my truck rear brakes rust so just fronts brakes it stop good, I got 7lbs vacuum with brake booster.
Title: Re: brakes
Post by: Boggen Joe on June 10, 2014, 01:31:35 AM
Stock 80s Chevy truck master. Running both ports into a T single line to frame then back to a T to calipers.
Title: Re: brakes
Post by: michigan maniac on June 10, 2014, 01:59:31 AM
Pinion brake is where its at, mount one off the 14 bolt and you will stop on a dime
Title: Re: brakes
Post by: Boggen Joe on June 10, 2014, 12:49:22 PM
Quote from: michigan maniac on June 10, 2014, 01:59:31 AMseems like a lot of stress on that little bearing though
Title: Re: brakes
Post by: michigan maniac on June 11, 2014, 12:15:04 PM
Then my other option would be install a hydro boost off a newer Chevy truck or astro van where it runs off your p.s. pump, or find an new master designed to run disc brakes off a single piston with no booster, I would assume summit or jegs would have them for drag cars
Title: Re: brakes
Post by: Rohde009 on June 11, 2014, 02:02:01 PM
Hey joe I run the same thing as you do but I have only rear .I ran both lines from master down to frame teed them together ran to back and teed once again for the rear calipers on my 14 bolt and I have very good brakes
Title: Re: brakes
Post by: 4x4xdodgeman on June 12, 2014, 03:44:42 PM
are both front brakes working?
Title: Re: brakes
Post by: Boggen Joe on June 13, 2014, 01:18:20 AM
Yes both working. Humm maybe different master? Any suggestions
And guess I could try rear disc
Title: Re: brakes
Post by: Blazin40s on July 24, 2014, 04:03:06 PM
Get the rear disc Joe.
Title: Re: brakes
Post by: Hammerlane on July 24, 2014, 04:39:35 PM
no booster.. what size line are you using and how much of it is flexible ???
Title: Re: brakes
Post by: tmspike on July 26, 2014, 01:12:14 PM
I have rear disc on my chevy and nothing on front and works great. But its strictly a mud truck.  Im running a single 1/4 inch line to the back and then teed into 3/16 at the pumpkin.  I also am using front port on master and plugged the rear port.  I dont have a booster and it works great.
Title: Re: brakes
Post by: Jthomas on July 27, 2014, 11:38:54 PM
Try a vacuum canister?
