Projects & Parts => Garage/Tech => Topic started by: michigan maniac on June 12, 2014, 12:55:56 AM
Title: kill switch
Post by: michigan maniac on June 12, 2014, 12:55:56 AM
I'm looking into putting a kill switch on my bogger, I won't be running comp bogs or anything like that but I want a secondary shut down just in case, what brand of switch does everyone prefer ?
Title: Re: kill switch
Post by: Wild One on June 12, 2014, 01:35:51 AM
http://www.summitracing.com/parts/sum-g1432/overview/
I like ones like this.
Everything is off!!!
Steve's Oxford Automotive carries, so does Deerfeild
Post by: michigan maniac on June 12, 2014, 02:06:15 AM
After looking into it more I guess I really need to see if my alt will continue to run when batt power is shut off to determine if I need a 2 pole or 4 pole switch
Post by: Captn. J on June 12, 2014, 12:22:25 PM
i use what harbor freight had    been 2 years     works good
Post by: Hammerlane on June 13, 2014, 04:47:20 PM
a simple single throw toggle to the hot side of the coil will work just fine.
its a 12v low amp circuit.
