If you have a mid 90's dodge with the v10 or cummins, i need to get some drivetrain measurements so I can decide what I'm going with in my bogger.
Either going with 4wd trans & tcase or 2wd trans and divorced case.
i have a 97 ext cab 4x4 with a v-10. What measurement do you need. i can get you the info after dinner tonight.
I need to know what the distance is from the back of the engine block to the rear yoke on the tcase. Basically, how long the trans and tcase are. Doesn't have to be precise just trying to figure out where everything is going to sit in my frame. Thanks :)
I should have them for you around 6:00 tonight.
Quote from: lilred on August 25, 2014, 06:05:23 PM
It is 49 1/2" from back of block to center of yolk. The trans case is 22 1/2" from front face to center of yolk.
==cl thanks ;D anyone have a 2wd?
