I made the ladder bar for the rear axle for my boat so no more axle wrap i hope maybe next year tug n war at TGW it's not done, hopefully tomorrow. i m still figuring out what i wanna do with the front axle. My dad says he could see the axle wrap in the front too but not too bad. maybe 4 link the front would help. I never seen anyone with ladder bar up front.
Whats the wall thickness? They look pretty sweet.
2 by 2 inch sq 3/16 inch thickness on the outside and 1 by 1 inches on the inside 1/8 inch thickness
Better clean that garage before it floods again...
first picture is at my father in law s garage then the rest is in my garage. The flood happen at my dad s garage where my boat could barely fit in with small tires and thats where the fire happen... i dont think there will be any flooding this year my dad and i cleared the floor drain and added new tile drain outside around the garage so hope that will help.
Do you have leaf spring front ? And if so are the swing shackles on front of springs or rear.. if the shackles are on the rear you can build one single bar from front of frame down to axle, build a helmet for rockwell and secure to the top of the chunk, if shackles were in the front of the springs you can build regular ladar bars like you did for the rear, basically any type of ladar bar has be to attached to the frame opposite of the swing shackle
Leaf in the front and the shackle is in the rear of the spring
